Old 04-05-2007, 03:16 PM   #1
benoit454
Chris
benoit454's Avatar
covering dash with material???
Hey guys I've seen a few here and there but always wondered about this...
How do you go about wrapping the dash in material? Such as cloth maybe vinyl?
I've seen guys on tv use vinyl and a heat gun since it strecthes and do that.
But if you use carpet or some other cloth then how?
I'm worried about wrinkles, and fadeing. I know most carpet would fade and our dash is in the sun all the time. it's an 84 and it's blue, looking at covering it in the closest blue I can get that match or maybe use just anything and then dye it that exact blue.
Anyone have any tips or ideas on done it before?
It looks to me like what would be hard is where it drops off after the guage bezel and goes over to the passengerside, since you'd need to pull it under in the front over the guages, and then down and over to the passengerside. I'm really lost on it, unless maybe you fold it over like I did my sub box, then cut both ends together so it makes a nice flat part that you can hardly see the seam of the 2.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 04-05-2007, 03:45 PM   #2
liljon285
That Guy
liljon285's Avatar
Re: covering dash with material???
I used a kit LMC has that is like a plastic mold and it goes right over the dash and it also supplies the glue to glue it, the dash is heat prtected so it wont bend or get from the sun.
1978 Chevy Scottdale Stepside, 3rd engine- 350c.i. built with cam and lifters, holley 670cfm carb. and intake,heads shaved .60. Truck is a project, and I am its restorererer!
liljon285 is offline   Reply With Quote
Old 04-05-2007, 03:46 PM   #3
Blackstone
Blackstone's Avatar
Kinda hard to see in this picture, but my donor truck has this fuzzy black material wrapped around the dash pad. The guy got decent results using 3M spray adhesive, and cut the stereo into the center of the dash pad. I can't imagine that this material was stretchable, but it fit surprisingly well around the instrument panel. I did notice upon closer inspection, a seam about 1-2 inches to the right of the instrument panel, but I really had to look hard to find it. I'll try to post a better picture of it tonight.
Blackstone is offline   Reply With Quote
Old 04-05-2007, 03:54 PM   #4
benoit454
Chris
benoit454's Avatar
I know they have the molded plastic ones.
Thoose are not the ones I'm talking about though, or ANY you can buy really.
I'm talking cheaper custom stuff, buy a yard or two of material and do it myself.
if I can't find anything or I try it and don't like it I'm gonna buy one of the molded plastic ones.
Chris
GIT R DONE!!!!!!
Old 04-05-2007, 04:55 PM   #5
edman87
junk collector
I tried vinyl with a heat gun and industrial adhesive, it didn't go real well. Just couldn't get enough stretch for the curve/ hump on right side of inst cluster. If you didn't mind a seam in it right there, it could be sewed together to work pretty good. A high heat, high humidity vacuum chamber chamber would work, but I don't have 1!
'87/89/76 K5 in progress
'99 K2500 short crew
'91 camaro rs
'98 jeep tj
'52 willys cj3a
edman87 is offline   Reply With Quote
Old 04-05-2007, 05:05 PM   #6
benoit454
Chris
benoit454's Avatar
LOL Me either!!!!
I'm thinking most who have done it or have it done must have seamed it.
I guess that's why they use something thick and/or fuzzy like carpet or tweed or something.
Chris
GIT R DONE!!!!!!
Old 04-05-2007, 06:02 PM   #7
edman87
junk collector
Whatever you do, don't put the dead poodle on the dash, it is just tacky!
My brother in law runs 1 of those carpet covers on his and it screams ghetto.
If all else fails you can strip the vinyl and foam and glass it. I am thinking of trying this on a spare I have. I am thinking glass and then spray on bedliner stuff over that. Never seen it done, but I think it would look good and match my interior.
'91 camaro rs
'98 jeep tj
'52 willys cj3a
Old 04-05-2007, 06:04 PM   #8
edman87
junk collector
BTW, I have heard of uposlstry shops covering them and it turning out nice, but i imagine it would be pricey. Besides, it is hard to find someone that will do off the wall stuff, you know, other than a simple swap or slip on re-cover.
'91 camaro rs
'98 jeep tj
'52 willys cj3a
Old 04-05-2007, 06:51 PM   #9
knightlife
Dark Heart Motorsports
knightlife's Avatar
I wrapped my dash in speaker box carpet, used 3M spray adhesive (the heavy duty ****). worx really well
How Deep Can YOU Bleed..?
1985 Chevy Blazer K5- 6.2 N/A, 400 turbo trans CUCV, 12v converted... a new chapter
2005 GMC Sierra Crew Cab 6.0 powwwaa!!! custom jumpseat install w/ captain seats, Hypertech tuner, MSD Blaster Coils, CB and twin antenna's, all electric interior, touch screen in dash. custom center console, with jump seat replacing original console. 1500 HD!
knightlife is offline   Reply With Quote
Old 04-05-2007, 07:50 PM   #10
neverfinished
I'm considering this too. What my plan was, if I can't get the vinyl to stretch enough to make that curve is to make it in two pieces then fold some vinyl over a strip of sheet metal and make an accent stripe to cover the seam. I'm going to try doing the kick panels and door panels first though so I'll have a good idea of what it takes to work with the vinyl.
neverfinished is offline   Reply With Quote
Old 04-05-2007, 09:01 PM   #11
Blackstone
Blackstone's Avatar
Here's a better look at mine...
Old 04-05-2007, 09:04 PM   #12
benoit454
Chris
benoit454's Avatar
Nice pics, that looks like the thin carpet I got from autzone to do my sub box in.
Have any troubles getting it to lay down and not wrinkle and were able to wrap it around without them knightlife?
Chris
GIT R DONE!!!!!!
Old 04-05-2007, 09:57 PM   #13
knightlife
knightlife's Avatar
holy **** thats my dash! well...almost, I have billet accents on mine where his stereo is
Old 04-05-2007, 09:59 PM   #14
knightlife
knightlife's Avatar
oh btw...heres where I buy my vinyl in bulk from...
http://www.rvinyl.com
Old 04-05-2007, 11:59 PM   #15
benoit454
Chris
benoit454's Avatar
Page is temp. unavailible.
Chris
GIT R DONE!!!!!!
Old 04-06-2007, 10:59 PM   #16
Pyrotechnic
Pyrotechnic's Avatar
Why not put the stereo in the stock location? A DIN sized radio will fit perfectly.
Pyrotechnic is offline   Reply With Quote
Old 04-07-2007, 05:39 AM   #17
Ivan D.
glamoros piece o' lowlife
Ivan D.'s Avatar
Oh geez, y'all and yer carpeting - just do like me, strip the dashpad down to bare metal and paint it with spray-on bedliner. You got nice shiny black that don't fear sunlight, and it's got texture to it too. Here's a pic for y'all:
The more I drink, the more I drink, the more I drink...
diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express
Ivan D. is offline   Reply With Quote
