Old 09-05-2002, 04:19 PM   #1
slick63
update to power disc brakes
i am in the process of getting rid of old brake master cylinder,already bought conversion from classic performance ,new brake line kit from inline tube. problem with running new lines previous owner removed all lines and brackets for powder coating.any technical support from anyone who has done this before would be appreciated.new brakes are power units w/front disc
slick63 is offline   Reply With Quote
Old 09-05-2002, 06:13 PM   #2
Mike C
Mike C's Avatar
In routing the lines, the old ones that connected to the drum brake lines were behind the crossmember. The new factory lines go in front of the crossmember. I whacked the bracket off the back of the frame on the parts truck and welded it to the front of my frame after bolting everyting up. Everything else is just a matter of putting parts in their place.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 09-05-2002, 09:24 PM   #3
slick63
thank you mike more help than inline tube
