Old 04-05-2007, 07:32 PM   #1
KennyB49221
Unhappy 1987 Chevy suburban not charging problem
Hey everyone, Im new to this forum and I know a little about electrical but and not an expert or anything. So heres my story.
My alternator was replaced but was charging during driving and my battery died, so i had it tested on the truck it was only giving 11.6 volts and not may amps. I had it tested off the truck and it was fine they said ( at Autozone). my battery is new. I got into it with one of the guys at the zone and finally he let me replace my alternator again with a new one. Same problem, not charging. Ive checked grounds , replaced my ground battery wire. Im thinking of replacing the wire to the alternator from the battery (+). NO fuses are blown, unless there is one inline with the wire from the harness to the alternator. it looks like that wire was repaired by the previous owner anyways. Also the truck has only 90,000 miles so im thinking this is a older engine b.c its carburated. Are there older sub. engines that were externally regulated with a voltage regulator. Please help. P.S. I also repaired the wire from the battery to the starter. The truck starts fine, just wont charge when running. I dont drive far could that be a problem too?
KennyB49221 is offline   Reply With Quote
Old 04-06-2007, 01:30 PM   #2
rcbildr
rcbildr's Avatar
Re: 1987 Chevy suburban not charging problem
Welcome to the board.
It sounds to me like you are going to have to take apart the wiring to your alternator. Take out the wires from the plastic loom and see if there are any bare spots or questionable areas.
I'm workng on an 84 Suburban and there is a fuseable (sp?) link, if you have one there (I'm not sure about the 87) see if the connection there is bad and maybe even replace the link. Check the juntion box on the firewall...there should be 2 large pink wires going to it. If I remember right, my 85 burb has a couple fueable links down by the starter...if your burb has them, check them out or replace them too.
It couldn't hurt to rework any of the crimp-on connectors or replace them with the twist-together type.
Hope this helps.
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
