Old 04-05-2007, 07:55 PM   #1
flatheadnut0
New Member
88 fan and radiator
I'm tearing down an 88 and do any of you know if I can use the fan and radiator. It is the first year of the serpentine I think. I guess I should tell you it's going on a 350 in a 67.
Last edited by flatheadnut0; 04-05-2007 at 07:56 PM. Reason: for got to add truck year
flatheadnut0 is offline   Reply With Quote
Old 04-05-2007, 09:04 PM   #2
centsless
sufficiently talented fool
centsless's Avatar
Re: 88 fan and radiator
If you use the serp. belt setup, use the water pump as well. The serp belt pump runs counterclockwise, the v belt pump runs clockwise.
"it's impossible to be surrounded by idiots when you are part of the circle"
2003 Suburban
2002 Pontiac Montana
1981 Corvette
1966 Impala Convertible
Click here to support the board
centsless is offline   Reply With Quote
Old 04-05-2007, 09:09 PM   #3
GREASEMONKEY72
GREASEMONKEY72's Avatar
you cant use the fan unless you use the whole serpentine setup because youd be pushing the air away from the block instead of at it
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 04-05-2007, 09:21 PM   #4
Yes you need everything, as I think even the alternate runs in the opposite direction. Going to the late model serpentine setup is a great upgrade IMO.
