Old 04-05-2007, 09:32 PM   #1
HugrOrang71
Bite me, import boy
HugrOrang71's Avatar
Instrument cluster panel for aftermarket gauges
I am looking for an aluminum panel to fit in the stock location to mount a set of aftermarket gauges on a 65. I've seen them for the 67-72 and early pickups, but I haven't found anything for 63-66.
Thanks,
Jason
Jason
'71 C-10 Deluxe-under construction '69 C20, 396,T400-donor truck, '65 C10 project
"Facts are meaningless, You can use facts to prove anything that's even remotely true."
HugrOrang71 is offline   Reply With Quote
Old 04-05-2007, 11:10 PM   #2
SIR
SIR
SIR's Avatar
Re: Instrument cluster panel for aftermarket gauges
...haneline gauges and panel... www.haneline.com
66long low fleet http://community.webshots.com/user/LVNR66
SIR is offline   Reply With Quote
Old 04-06-2007, 12:03 AM   #3
Hooky
I love the gauge/dash setup thatg SIR has from Haneline. There is also another version using autometer gauges at http://brothersonlinestore.com/prodi...number=CGP6600 Personally I like the Haneline set up better. What gauges did you use SIR?
Hooky is offline   Reply With Quote
Old 04-06-2007, 12:12 AM   #4
mnky30
mnky30's Avatar
Thanks,
Jason
i found instrument gauge cluster in the classic truck mag at www.docskustom.com for 140 ish.
vince
mnky30 is offline   Reply With Quote
Old 04-06-2007, 01:17 AM   #5
slepysal
slepysal's Avatar
How about a cheep home made one ?
Name:  new dash 2.jpg
slepysal is offline   Reply With Quote
Old 04-06-2007, 01:37 AM   #6
19GMC63
19GMC63's Avatar
Anyone know if someone makes an insert for a GMC?
19GMC63 is offline   Reply With Quote
Old 04-06-2007, 09:47 AM   #7
Chevy Fleetside
Chevy Fleetside's Avatar
I saw these gauges at the car show and decieded I wanted them for my truck.. How have they been holding for you Sir?
Chevy Fleetside is offline   Reply With Quote
Old 04-06-2007, 10:20 AM   #8
HugrOrang71
Bite me, import boy
Thats exactly what I need. I thought I had seen them before browsing for parts on my 71, but when I looked back through my catalogs I couldn't find them again.
Thanks,
Jason
Jason
Old 04-06-2007, 11:30 AM   #9
kwkenuf
Retrofit Management
kwkenuf's Avatar
Ebay for the aluminum panel.
My retrofit fleet
-1966 Suburban 2002 Tahoe drivetrain, firewall, floor, chassis and interior in progress
-1965 C-10 shortbed stepside, 2003 5.3/4L60E conversion. Power steering, tilt wheel, power front disc brakes, 2.5/4 inch drop, relocated fuel tank and battery, 2002 Silverado buckets and console. Swap Pics
-1968 Camaro 95 LT1/4L60E lots o' mods Web Page
-1961 Corvette project Corvette Corrections frame, C-4 suspension and brakes, 02 LS1/T-56, Never ending body workPics
kwkenuf is offline   Reply With Quote
Old 04-07-2007, 11:20 AM   #10
mbgmike
We sell these. They are custom made they are a two panel set. The gauges mount to the inner panel and the outer panel fits over to cover up the rim on the gauges. Its just a little different. They can be powder coated. We do not sell them polished as it tends to scratch easily. They only fit Autometer gauges which we can provide if wanted.
mbgmike is offline   Reply With Quote
Old 04-07-2007, 12:42 PM   #11
zapper
I don't know if anyone else has noticed but on ebay I always see the same old stuff like fenedrs, rockers cab corners. I know you always have to keep checking which I do, but there dosen't seem to be many good used parts for these trucks.
zapper is offline   Reply With Quote
Old 04-08-2007, 12:37 AM   #12
Captainfab
60-66 Nut
In the past I've had to make them myself. The GMC's are a little more work since the gauge panel and the bezel are one piece. You just have to cut them apart, leaving a lip on the bezel so you have a place to attach the new gauge panel. IIRC there is a groove that you can cut in as a guide and it leaves enough of a lip.
Old 04-08-2007, 12:52 AM   #13
HugrOrang71
Bite me, import boy
kwkenuf,
Is that a copper color, or is it just the lighting?
Jason
Jason
Old 04-08-2007, 11:57 AM   #14
Fred T
Cantankerous Geezer
Fred T's Avatar
The color appears to be anodizing. It's a coating process used on aluminum, can be done in several colors. Relatively hard surface. When done properly, it won't peel or scratch in normal use. We used it a lot on aircraft parts.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 04-08-2007, 01:26 PM   #15
62 short step
62 short step's Avatar
I got mine from Dolphin gauges.
62 short step is offline   Reply With Quote
Old 04-08-2007, 02:05 PM   #16
SIR
SIR
SIR's Avatar
....very well no issues what so ever..very pleased.......
Old 04-08-2007, 09:04 PM   #17
kwkenuf
Retrofit Management
kwkenuf's Avatar
kwkenuf,
Jason
Nope, it's actually just polished aluminum.. poor picture I guess....
My retrofit fleet
Old 04-08-2007, 10:12 PM   #18
HugrOrang71
Bite me, import boy
Thanks to everyone for your responses.
Jason
Jason
