Hot Rods For Life
3 " Lowering Block Kit - Get in the Zone
Autozone sells a 1", 2" & 3" lowering block kit. It's universal. I picked the 3 " one up for 34 bucks. Comes with ubolt, block and all hardware. I'll try to get it installed this weekend. I had a set of 2" block on a little Isuzu truck years ago that seemed to be ok.
Broke and still trying
Re: 3 " Lowering Block Kit - Get in the Zone
Careful with those cast aluminum things. They have a tendency to snap in pieces and leave you with one butt cheek in the air! LOL!
Zumo, is your truck leaf? I can't imagine a universal kit working for a coil truck.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
Hot Rods For Life
It's a coil. It was an impulse buy, but I am still gonna try so we'll see. I kept the receipt.
The LuvShack Garage
![]() j/k - Be sure to snap a few after they are installed ![]()
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
before installing you just might want to slide them on the ground under the trailing arms to see how much ground clearance you'll have when installed
That`s the problem with blocks,especially 3".The arms are way down there at the axle.
Hot Rods For Life
Ok. Thanks for the help guys. I am a little skeptical but not enough to keep me from doing it.
Active Member
![]() Join Date: Dec 2004
I have heard to stay away from the cast ones as well. I picked up a set of (I think) 2" ones at Pep Boys for the same price, and they are extruded aluminum, which is supposed to hold up better. It's looking like I'm not going to need them though.
1957 GMC Ambulance 1962 Belair Wagon 1963 C80 Truck Cab *FOR SALE* 1969 Chevy C10 Short Bed 1972 Chevy C10 Long Bed *SOLD* 1996 C3500 Dually *SOLD* |
#10 | |||
Union Electrician
I would not reccomend anything over a 2" block for our truck, The 3" like others have said will put the trailing arms too close to the ground and will be dangerous, just my .02...Randy
![]() ![]() Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
Hot Rods For Life
Didn' think about that. They did have 2" blocks too.
#12 | |
Next project: 1970 K10
![]() If any block extends the bottom of the trailing arm lower than the bottom edge of the rim, I wouldn't use it.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
#13 |
F.A.S.T. president
![]() Join Date: Sep 2003
I dont think you can use the universal blocks on the coil spring rears. It takes a totally diffrent setup. I built my own and welded them in. The block must have the two big holes to run the U-bolt thru. From what I remember the universal ones are to small in length and width. I have 5" springs and 2" blocks and I had to use a 2 deg wedge to pitch the yoke to the right angle.
F.A.S.T. President and Founder Fabricators for the Advancement of Sawsall Technology "A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis" Last edited by jamis; 04-06-2007 at 11:04 AM. |
#14 |
You can use them as a "setup" to see what the truck will look like. Cheap but some work. Also think Tethered racing car or Boat anchor! In CA I believe there's a Vehicle Code on having any part of the vehicle below the rim line just for that reason of digging and making an anchoring point. Just a word of caution, you're a grown up...Have at it. By the way...cool truck and graphix!
#15 |
its all about the +6 inches
You'll also want to look at where the end of the U bolts reach... the arm may be fine, the U bolt will be closer.
#16 |
Hot Rods For Life
I think I better exchange them for the 2" just ot be safe. I am glad I posted it here. I also borrowed a pick from a members build thread to try and figure it out here at work. Since I am not home in the garage.
Definatly looks like it will put my below the rim line. |
#17 |
Another thing to keep in mind.....when you add the blocks, it will extend your shocks too. Ex: 2" block will pull your shocks another 2" out. You can buy aftermarket lower shock mounts, or do what I did. I flipped mine upside down and side-to-side. I had to cut and reweld a small section on each one, but it helps to keep the shock from being too far extended, and it puts the shock bolt up rather than down where it could catch something since it is now lower to the ground.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 04-06-2007 at 11:42 AM. |
#18 | |||
Union Electrician
#19 | |
![]() Join Date: Aug 2005
The panhard angle does change since it ties to the rearend. But you only need shorter shocks and relocators when you used lowering springs. Last edited by Frizzle Fry; 04-06-2007 at 01:00 PM. |
#20 |
Ah-ha, I stand corrected
#21 |
Hey, at least your still standing
![]() Last edited by Frizzle Fry; 04-06-2007 at 01:05 PM. |
#22 |
Cool idea = cheap in this case!
#23 |
Hot Rods For Life
I swapped them out for the 2". Eventually I plan to C notch and add my bags but for now I'just run som blocks and shorter springs up front.
#24 | |
Active Member
#25 |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Andy, look in the FAQ at the article I did on lowering blocks. I show how to build some medieval burly ones for cheap. You can get the u-bolts at Ft Worth Champion Spring on Henderson Street. The article explains it all with pics.
