Junior Member
Hard Brake Pedal
what suggestions can I get to help fix my brakes, the pedal is very hard. It stops fine but you have to stand up on the pedal to get it to stop and when at idle it still does not hold very good. The pedal does nto go to the floor so it has plenty of pressure in the lines. New booster about a year ago...so any suggestioins?
thanks! |
Resident Absorber
Re: Hard Brake Pedal
could be collapsed hose(s)
The best offense is a better DEFENSE! |
check for a vacuum leak as well.
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill |
Junior Member
![]() Join Date: Jan 2007
I would check the vacuum line for the booster. Sounds like the brake booster is not helping you somehow. Maybe even a bad booster....it happens.
68 LongStep 350/ 3 Spd (ongoing project) 04 Suburban Z71 (daily driver) 97 C5 Corvette ( sold when 2nd baby came) 90 454SS pick up (sold) 1970 Chevelle Malibu 454 For Sale $8,000. my art website http://www.louietrangallery.com/ my 68 Longstep...No Shortstep Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=296736 |
Junior Member
how would I check the vacuum?
I thought superman could stop a truck without brakes!!
-Scott- |
GEARHEAD
Hey ya I seen him do that to a train once too!
had the same problem on my 72, you had to stand on the pedal to get it
to stop, changed the booster now the brakes are great.
Mike K Friend of Bill W |
still buypickupparts
same problem last week, looked at the booster vacumm hose and it had a bend in the routing, I changed the routing and wala fixed works like it was made to work now
Its Gonna be a Great Day, I woke up this Morning. 72 SWB Fleetside freshly painted. putting a 94 LT1 with 700R4 tranny lowered 4 in the front 6 in the back 81 chevy half ton 350 89 Silverado 4x4 going ta church truck |
its all about the +6 inches
unplug the large vac hose that goes to your booster, and shove a big bolt or something in there. Start the truck up, and see if the brake pedal feels the same.
With engine off put foot on brake and hold pressure. Start truck. If booster is working pedal with lower a small amount.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
#13 |
if it's a 3/4 ton or one ton, that test isn't totally conclusive. I lost an engine due to a bad booster that passed that test.
#14 |
Junior Member
I belive it is the booster. I unplugged the vacuum hose and there is plenty of vacuum there. with the hose unplugged the brakes still felt the same. I am going to put a new one on tommorrow and see what happens. Changing the MC too, just in case..
