04-06-2007, 01:17 AM | #1 |
STOLEN
Battery Drain
I have had a battery drain, and I think I narrowed it down to the Horn Relay thanks to this site. My question is... do I just replace the relay or do I still search for an exposed short in the horn wiring?
In Search Of |
04-06-2007, 08:48 AM | #2 |
Re: Battery Drain
I would suggest disconnecting the large red wire to the alternator to see if the problem goes away. The alternator diodes can back feed into anything that has battery voltage to it causing some strange shorts.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
04-06-2007, 11:36 AM | #3 |
Re: Battery Drain
Unplug the black wire to relay. If drain goes away the black wire is grounded somewhere between there and the horn button.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
