Old 04-06-2007, 09:07 AM   #1
killthewabbit
Spear and magic helmet!
killthewabbit's Avatar
Anybody got pics of 275/60-15 tires on 8" wheels?
I've been rolling the same wheel/tire combo as cliffsta's old truck for a couple years now, 8" Eagle 058 wheels with 255/70-15 tires.
My tires are getting a bit worn out and I've been kicking around the idea of changing the tire size. Anybody got pics of 275/60-15s on an 8" wheel? I'd really like to see how they look.
My truck's a 78 SWB stepside 2wd. Again, very similar to cliffsta's red truck.
Thanks in advance.
-- Will
killthewabbit is offline   Reply With Quote
Old 04-06-2007, 09:25 AM   #2
Blackstone
Blackstone's Avatar
Re: Anybody got pics of 275/60-15 tires on 8" wheels?
Here's a picture turned up via Google search. 275/60 is the ideal tire size for a 15x8 wheel IMO. Shouldn't affect your speedometer calibration a whole lot, assuming the truck was equipped with 235/75-15 from the factory.
http://www.manracingpromotions.com/i.../trk_4sale.jpg
Blackstone is offline   Reply With Quote
Old 04-06-2007, 11:18 AM   #3
killthewabbit
Thanks, Blackstone. I got that same one back from a GIS myself. My speedo calibration is already off, so that doesn't bug me much.
I was hoping some of the members would have this combo on their trucks for some info. I've seen 275/60 tires on 15x10 wheels a lot, but I don't know anyone with 15x8 that's running them
-- Will
Old 04-06-2007, 11:22 AM   #4
Jonboy
Slots go on anything!
I had an old Suburban with thte 275/60's on 8" rally wheels, and they fit just fine. I didn't take any pictures, as that truck was so ugly, it would have broken the camera.
Old 04-06-2007, 01:38 PM   #5
Slonaker
Insert Witty Text Here
Slonaker's Avatar
It kind of depends on the tire. It is like buying shoes. Two brands in the same size may not fit quite the same.
When I bought my tires, I found that BFG Radial TAs in 255/70/15 looked the same as 275/60/15s from Dunlop. When I compared them in the same size, the Dunlops were noticeably smaller.
That said, I have never seen any 275/60/15 tires on a 8" wheel that looked bad. Some just fit better than others. You will probably be happy with either size.
This pic is of my 8" rallys with the old 255/70/15 BFGs with white letter out:
This is a pic with the new 255/70/15 BFGs mounted blackwall:
I think they are just about the right width for the wheel, but the 275/60s would fit just fine. The sidewalls would just pull in a little bit.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 04-06-2007, 03:16 PM   #6
kevinr1970
Only picture I got here.
255/60 - 15 front, 275/60 - 15 rear.
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 04-06-2007, 06:09 PM   #7
BaddBusa2005
BaddBusa2005's Avatar
295/50/15 all the way around.
1981 Custom Deeluxe SWB 5.3/4L60e 3.73 and Auburn. Mustang Dyno 265hp/258tq
BaddBusa2005 is offline   Reply With Quote
Old 04-07-2007, 05:33 AM   #8
Ivan D.
glamoros piece o' lowlife
Ivan D.'s Avatar
They fit fine, had some 275/50s on 15x8 wheels on my car last summer and they looked dead on. 295/50s on 15x8 is already pushing it and will cause lots of sidewall flex during hard cornering, but as long as you don't try to take a 30mph tight turn at 55+ you should be fine, only the center of the tread will wear like the tire's been overinflated.
The more I drink, the more I drink, the more I drink...
diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express
Ivan D. is offline   Reply With Quote
Old 04-07-2007, 08:08 AM   #9
killthewabbit
Thanks fellas. Keep 'em coming if you have more
-- Will
Old 04-07-2007, 08:50 AM   #10
68Stepbed
68Stepbed's Avatar
275/60/15 T/A Radials on my brothers 83. 275/60/15 Dayton Daytona S/R's Blackwall and WLO on my 86.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 04-07-2007, 08:54 AM   #11
7T2
Active Member
7T2's Avatar
275/60/15 on 8" on the rear
245/60/15 or 7" on the front
1957 GMC Ambulance
1962 Belair Wagon
1963 C80 Truck Cab *FOR SALE*
1969 Chevy C10 Short Bed
1972 Chevy C10 Long Bed *SOLD*
1996 C3500 Dually *SOLD*
7T2 is offline   Reply With Quote
Old 04-07-2007, 12:19 PM   #12
Slonaker
Slonaker's Avatar
Are those 10" aftermarket rally wheels? If so, are you running trim rings meant for 8" wheels, or what?
Slonaker
Stock '01 Silverado
Old 04-07-2007, 12:45 PM   #13
56chevy1300
56chevy1300's Avatar
here's mine...275/60R15's rear 245/60R15's front.
56chevy1300 is offline   Reply With Quote
Old 04-07-2007, 01:59 PM   #14
stepside454
stepside454's Avatar
here you go. the first pic is with 275/60/15s on 8" rally
Second pic is 285/70/15s on my 8" Centerlines...I hear BFG no longer makes the 285/70ss
75 GMC C-15 short/step factory 454, lowered
stepside454 is offline   Reply With Quote
Old 04-07-2007, 03:33 PM   #15
BaddBusa2005
Slonaker
No, they are gm 8" wheels. The factory trim rings I did not like and bought to after market stainless rings that did not go all the way to the wheel.
