04-06-2007, 01:16 PM | #1 |
Power steering stutters
Like the title says, Well that is the best way how I could describe it.
This is what happens, I want to make a turn, and the wheels turn difficult, they don't turn smooth. And you hear a screeching sound sometimes, mainly when the wheels are at the end stop (but also while steering). (Funny enough it's harder to steer to the right then it is to the left...) I found that the return hose was bent very sharp, almost closed it off,so I replaced that hose, thinking that might be the problem. I bleeded the pump and did the full turns with the wheels of the ground. No problem there, but with the wheels on the ground no improvement. Still very hard to turn the wheels, and with the stutter. What could cause this problem? Is it the pump, or the steering gear? Thanks for any ideas on this. Cya, Edmond Dutch Longhorn
1971 Chevy C/20 Longhorn, 350/TH400, Edelbrock Performer, IMPCO 425 LPG Carb 1974 Chevy Camaro Z28 (Original) ------------------------- The Netherlands |
04-06-2007, 01:23 PM | #2 |
aka TEX-TOY
Re: Power steering stutters
I am having the exact same problem! I was thinking about getting a new Sterering pump.... Any ideas?
1969 Chevy C10 SWB w/ disk brakes and soon to be lowered with spindles and springs!!!! Getting a paint job like a Army Chinook Helicopter!!!! HOOKERS RULE!! BRAND NEW WIFE BOUGHT IT FOR ME AS A WEDDING GIFT!!! SHE IS THE BOMB!!!!!! |
04-06-2007, 01:26 PM | #3 |
* Air in the fluide, foamy looking.
* Loose belt. ( Even if it seems tight, if it slips, it will cause this ) * low on fluide. Check those things 1st. Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
04-06-2007, 01:29 PM | #4 |
I survived Dead Man's Curve.
The power steering fluid foams up when you first start using it. You should start her up, turn the wheels left to right and back very slowly. If it foams up, give it sometime to settle down. Then add fluid if necessary. And repeat turning the wheels left and right and back, slowly and smoothly. SHould help circulate things better through the gear box. That screech is pretty common if you have a loose belt.
"The people should not be afraid of their government. The government should be afraid of it's people." "The Hurricane" 1967 Chevrolet C10 350 Eight Cylinder, 700R4 BowtieOverdrive Cherry Bomb... Disturbing the Peace Since 1968. Last edited by ThatOneBlue67; 04-06-2007 at 01:29 PM. Reason: Spellcheck |
04-06-2007, 03:20 PM | #5 |
I see no air or foamy looking oil in the pump.
Fluid level is ok. Could try to tighten the belt a bit more I guess. Thanks. Cya, Edmond Dutch Longhorn
04-07-2007, 07:33 PM | #6 |
Well I tightend the belt a bit more (hard to do on your own by the way) and it was indeed a great improvement.
The stutter in turning the wheels is gone, and no more screeching sound. Thanks guys!! Cya, Edmond Dutch Longhorn
