Old 04-06-2007, 03:49 PM   #1
sb69chevy
sb69chevy's Avatar
Overdrive Trans
Found a 67 truck in the yard today that had an overdrive transmission listed on its SPID. Tranny was gone, but there was a cable below the dash w/ "overdrive" placard around it. Never seen this before, just thought I would share. May not be any big deal. This truck also had an option that read something like "GM Air Inj Reactor"...What is this?
I'll go back and get pics next week, if wanted.
1969 C/10 swb, 350, powerglide (daily driver)
2005 CRV (wife's ride)
sb69chevy is offline   Reply With Quote
Old 04-06-2007, 03:55 PM   #2
gmc1969custom
Re: Overdrive Trans
Sounds interesting.
1969 Custom w/Turquoise Interior. 75k miles, 350 V8, THM400 (Almost) All Original
gmc1969custom is offline   Reply With Quote
Old 04-06-2007, 04:25 PM   #3
JHART
1972 Shorty Owner
JHART's Avatar
Location: Stationed in Cali , born and raised in PHX Arizona.
Re: Overdrive Trans
i'd like to see some pics .... sound wierd to me would like to see more.
1972 Chevy Shorty C-10- Project In Work
http://67-72chevytrucks.com/gallery/...ATT1721941.jpg- New Project
JHART is offline   Reply With Quote
Old 04-06-2007, 04:36 PM   #4
sb69chevy
sb69chevy's Avatar
Re: Overdrive Trans
Yeah, it through me for a loop, too. I was in a hurry to get to work or I would've gone back to get the camera. I'm glad the glove box was still in the cab floor. Is there a "rare" or hard to find steering wheel cap for these (67-68)?
Old 04-06-2007, 04:38 PM   #5
JHART
1972 Shorty Owner
JHART's Avatar
Re: Overdrive Trans
I dont know about "rare" but i do know lmctruck.com has some.
I never heard of a 67 with overdrive trans.... would be really cool find if it was though.
Old 04-06-2007, 04:39 PM   #6
1969k10stepside
Re: Overdrive Trans
There is a glass one that some people want
1969k10stepside is offline   Reply With Quote
Old 04-06-2007, 04:39 PM   #7
sb69chevy
sb69chevy's Avatar
Re: Overdrive Trans
I don't need one, just saw one in the floor of the same truck. Looked very nice. Were there 2 different styles maybe?
Old 04-06-2007, 04:39 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Overdrive Trans
the overdrive was a very weak tranny offered on the smaller engines. If I recall, it wasn't even strong enough to hold up to the little 327. They worked fine, and there's stillsome on the road today. They also came in cars of the late 60's too.
The air injection thing was very common in the late 70's up to the mid 90s or so... a smog pump would shoot air in the exhaust to help with emissions.
that horn button is a valuable piece if in good shape. A 67 only item, it was part of the CST package.
Old 04-06-2007, 04:43 PM   #9
sb69chevy
sb69chevy's Avatar
Re: Overdrive Trans
Okay, so not that big of a deal on the OD thing...The horn cap did have glass or hard plastic in the center of if it. Looked pretty good.
Old 04-06-2007, 05:32 PM   #10
ThatOneBlue67
I survived Dead Man's Curve.
ThatOneBlue67's Avatar
Re: Overdrive Trans
Could someone find a pic of that cap? I'd love to see what it looks like!
"The people should not be afraid of their government. The government should be afraid of it's people."
"The Hurricane"
1967 Chevrolet C10
350 Eight Cylinder, 700R4 BowtieOverdrive
Cherry Bomb... Disturbing the Peace Since 1968.
ThatOneBlue67 is offline   Reply With Quote
Old 04-06-2007, 06:04 PM   #11
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
Re: Overdrive Trans
The overdrives were pretty common in the late 50's and 60's especially in cars, but also found in trucks till they found out they coudn't stand up to normal truck use.
My Dad used to drive a 72 SWB w/ a 250 and a manual three speed column shift. He put an overdrive trans in it to lower the RPM's on the freeway. You could pull the cable under the dash to lock the trans from going into overdrive (like for towing). You shift through the three gears as usual, and when you were cruising along in third, you let up on the gas pedal and the trans would shift itself into overdrive. When you were cruising along in OD you could stomp the pedal and it would shift back to 3rd so you had a passing gear of sorts.
He would have to replace them every couple of years because they would tear up. He really was not hard on them either.
Edit about the air injector:
That is the emissions smog pump is it not?
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 04-06-2007, 06:07 PM   #12
ThatOneBlue67
Re: Overdrive Trans
Now are these automatic overdrives or the 3 speeds with an overdrive solenoid?
"The Hurricane"
1967 Chevrolet C10
Old 04-06-2007, 06:16 PM   #13
WorkinLonghorn
WorkinLonghorn's Avatar
Re: Overdrive Trans
. I'm sure you meant to type "late 60's up to...". My last '69 had the air pump and injectors because it was a 1/2 ton. Current 3/4 didn't have to have them. Talking California here.
Right.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 04-06-2007, 06:24 PM   #14
Re: Overdrive Trans
The o/d trans was a manual 3spd w/manual solenoid.This was about the last application on a`67.
That sounds like the CST horn cap and if the plastic is good it`s a hot little part.Heck,if you can get the glovebox door for cheap,I think JoesJunk would like to have that.
Old 04-06-2007, 07:03 PM   #15
sb69chevy
sb69chevy's Avatar
Re: Overdrive Trans
Plastic was crystal clear and chrome was not very pitted at all. Both cap and glove door were sitting in the cab floor. Don't know that all of the goodies underneath the cap were there, though.
Old 04-06-2007, 08:16 PM   #16
WorkinLonghorn
Re: Overdrive Trans
Wow,this is a new one on me. It seems like a good idea but it sounds like it was from the parts bin of a car line and not designed for truck duty. I'd like to find out more about this option.
Old 04-06-2007, 08:21 PM   #17
Re: Overdrive Trans
They were mostly in cars.
Just the horncap is all you need.The rest is the same and most would have that.Those parts are also available in repro.I wouldn`t say it`s ultra-valueable,but they should sell it cheap,Id think,and someone would want it here.I`m sure.
Old 04-06-2007, 08:23 PM   #18
too much stuff
Roadtrip!
too much stuff's Avatar
Re: Overdrive Trans
Overdrive trans from a 67 CST...
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 04-06-2007, 08:48 PM   #19
Longhorn Man
Re: Overdrive Trans
67 horn caps;
Old 04-06-2007, 08:49 PM   #20
Longhorn Man
Re: Overdrive Trans
I thought one of those was beside the normal booring horn cap... the normal one is like silver with black writing on it... looks very lame beside either of these two.
Old 04-06-2007, 08:52 PM   #21
sb69chevy
sb69chevy's Avatar
Re: Overdrive Trans
Longhorn, yep the one on top was the one I saw.
