Old 04-06-2007, 06:01 PM   #1
sb69chevy
sb69chevy's Avatar
Brake Booster from yard
I'm sure it's a crap shoot, but what's the odds that a yard brake booster will be any good? Also, what size/manufacturer would be recommended to use? I saw about 3 different sizes today. If nothing else, I'd like to have the brackets off of them. Do any of them sit close to the firewall?
1969 C/10 swb, 350, powerglide (daily driver)
2005 CRV (wife's ride)
sb69chevy is offline   Reply With Quote
Old 04-06-2007, 06:09 PM   #2
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
Re: Brake Booster from yard
Grab those brackets when you see them..can't have too many of those. Better get the rod from the pedal to the booster too though.
Your right it is a crap shoot to get one out of a wrecking yard. I guess youcould try one, and if it is no good use it as a core at your LFAPS. You can get a reman at Advance for $89
I'm not sure of the best size, or what the original size is for that matter...Ive never measured!
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 04-06-2007, 07:05 PM   #3
sb69chevy
sb69chevy's Avatar
I think I counted 4 sets of brackets and I know at least 2 were still attached to the brake pedal. What would be a good price for the brackets?
Old 04-06-2007, 07:45 PM   #4
rage'nrat638
rage'nrat638's Avatar
theres two sizes of brackets
BENDIX MAKES A SHORT & LONG BRACKET
DELCO MAKES A SHORT & LONG BRACKET
BOTH OF THESE SHOWN ARE BENDIX
THE FIRST IS A 1/2 TON SINGLE DIPHRAGM
THE SECOND IS A 3/4 DUAL DIPHRAGM
rage'nrat638 is offline   Reply With Quote
Old 04-06-2007, 07:47 PM   #5
sb69chevy
sb69chevy's Avatar
Will it matter which I use on my truck?
Old 04-06-2007, 07:54 PM   #6
rage'nrat638
o boy here we go...
#### need to edit my previous post ####
this is where the fun starts
this is what i understand (could be wrong)
bendix has the long adjusting rod sticking out of its boosters (master has a deep hole)
delco has the short rod (MASTER HAS A DIMPLE)
BOTH BOOSTERS SHOWN ARE BENDIX BOOSTERS
BOTH BOOSTERS 1/2 TON AND 3/4 TON HAVE DIFFERENT LENGTH RODS STICKING OUT THE REAR THUS THE DIFFERENT SIZE BRACKETS
THE PEDAL TO THE BOOSTER ROD SHOULD BE THE SAME BETWEEN THE TWO
THE MANUAL BRAKE TRUCK .. PEDAL TO MASTER ROD ..WON'T WORK WITH THE POWER BRAKE BOOSTER
Old 04-06-2007, 08:04 PM   #7
rage'nrat638
CONFUSED YET
REREAD EVERY THING I JUST ADDED A TON OF INFO TO BOTH PICTURES THATS EVERYTHING I KNOW..
THE TWO DIFFERENT MFG'S PARTS DON'T MIX
ASK ANYBODY ABOUT THAT
Old 04-06-2007, 08:09 PM   #8
rage'nrat638
as far as boosters from the junk yard..the only thing you can rely on there is that you will have a core to return
theres rubber diaphragms inside and rubber seals on the outside.. those are sure to be shot after 30 plus years
Old 04-06-2007, 08:09 PM   #9
sb69chevy
sb69chevy's Avatar
Yes, confused, but I'll figure it out. Let's say I put the bendix on the truck and the booster is bad...do they remanufacture each style of booster? I know, I'm dumb.
Old 04-06-2007, 08:13 PM   #10
sb69chevy
sb69chevy's Avatar
Okay, I have manual brakes, so are you saying the rod from booster to pedal wouldn't be able to attach? Need a pedal from a pb truck? If so, one was still attached.
Old 04-06-2007, 08:25 PM   #11
rage'nrat638
the pedal will be the same the rod will be different
the rod from the pedal to the back of the booster brackets
the best thing to do is take pictures of your rod and post them here on this thread so i can save the picture and label it.
if everybody did this we could have a very comprehensive
detail of the different brake set-ups on these trucks
this is what the rod looks like the one you need
Old 04-06-2007, 08:50 PM   #12
sb69chevy
sb69chevy's Avatar
Okay, thanks rat. I'll make sure that I take that w/ me when I get this set up. Will I need to drill new holes in the firewall, or will the bracket attach to the mc holes?
Old 04-06-2007, 09:00 PM   #13
rage'nrat638
Thumbs up Re: Brake Booster from yard
yes i think all the bolts and holes should already be there.
i know theres a few here that have done this conversion.
just wish we could get all the pictures and explanations together
your pal mark
Old 04-06-2007, 09:03 PM   #14
sb69chevy
sb69chevy's Avatar
Thanks again, Mark. Any idea what this setup will cost...ballpark?
Old 04-06-2007, 09:16 PM   #15
rage'nrat638
i bought mine at advance auto over the counter for 180.00
with the master cyl the 3/4 ton dual diaphragm model.
i have a 3/4 ton truck that had that black pictured 1/2 ton
booster on it.
i think auto zone has them cheaper but i don't like the auto zone by me.
i just degreased my new one and sprayed it with clear to keep it from rusting.
and used the existing master cyl
the last picture should be whats on your truck
you can see the bolts are already there !!!!
Old 04-06-2007, 10:39 PM   #16
Bus Ted Knuckle
Son of a gun
Yeah all of the bolt holes are there (with bolts in them already). there are 4 right around the master cylinder, you use one on the collar on the end of the steering column, and then iirc, one of the ebrake pedal bolts.
BEATERS ARE NEATER
Old 04-06-2007, 11:38 PM   #17
GMCMAX
Active Member
GMCMAX's Avatar
What I did on the 69 half ton, with pics
http://67-72chevytrucks.com/vboard/s...d.php?t=221598
Never try to teach a pig to sing; it wastes your time and annoys the pig!
Gets More Chicks
My lugnuts require more torque than your honda makes!
68 GMC, 4X4 conversion w/73 k20 running gear and springs, 350 4spd, 4.10's, D44 powerlok front, 14BFF govlock rear, 33" tires, lifted 4".
GMCMAX is offline   Reply With Quote
Old 04-08-2007, 01:03 AM   #18
Americanrider
Go get yourself a Mighty-vac hand pump kit:
http://www.harborfreight.com/cpi/cta...emnumber=38053
I paid $39 at Sears, but they are cheaper at Harbor freight. It come with an assortment of fittings and bleeder tips. At least one of the fittings will work on the Vac line inlet of the booster. Hook it up and pump it to about 20-25lbs and let it set for a minute. If the Vacuum bleeds down the booster diaphram is shot.
These hand pumps are great for doing a one-man brake bled once you install your new system. I have had mine for over 3 years now and it still works great.
On a side note:
I found a 64-66 brake booster in a wrecking yard for $12 and was able to test it. It held 25lbs for over a minute and I sold it for $50 bucks on Craigslist, it will pay for itself.
Americanrider is offline   Reply With Quote
Old 04-08-2007, 05:11 AM   #19
EAST SIDE LOW LIFE
EAST SIDE LOW LIFE's Avatar
I took my pwr brake set up out of my $200.00 dollar donor parts truck a 71 Chev P/UP. I detailed it, the booster showed no signs of being rusty so I took it that it had already been replaced. (works fine.)
I was always under the asumption that the perportioning valve on the pwr brake set up should be used instead of the manual one. Either will work but they are supposed to be different from each other. I always play it safe and swap every thing over. They appear physicaly different and thats enough of a reason for me to change it.
Parts cost free .... I stripped the 71 in about 2 weeks and had the wrecker tow it away ... tow charge free. Sold grill, head light buckets trim parts & got my $200.00 dollars back. This truck was not even for sale just sitting in this persons yard. I asked if they would sell it and the rest is history.
esll.
Tomorrow is for doing today's stuff.
This truck has just the right amount of energy for me!
Author: Warren Lake .... (member)
EAST SIDE LOW LIFE is offline   Reply With Quote
