Old 04-06-2007, 07:01 PM   #1
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
31s on stock 15' rims
Well I have 215/75r15 on my truck know with about o 2-3 in of room tell i even start to tuck the tires under the body of my 1986 chevy sliverado 1/2 2wd. I would like to put my tires from a set of rim on the truck, the tire size is 31*10.50R15LT.
My step dad says they will rub i disagree only cause my truck still sits high for a 2wd much higher then my other 86 c10.
P.s. my current tires are the world greatest bfgoodwrinch allterain t/a tires. I need to save money for some new tires cause two of mine are good the rear are bald after to many burn outs.
Ill try and find/ get a pic of the truck know. (it has chrome wagon wheels but same rims size as factory and the factroy ones are going back on it.)
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
Old 04-06-2007, 07:52 PM   #2
Blackstone
Blackstone's Avatar
Re: 31s on stock 15' rims
Here's a 2wd I had a few weeks ago with 31's and stock suspension, no rubbing:
Blackstone is offline   Reply With Quote
Old 04-06-2007, 09:54 PM   #3
Duro5341
Duro5341's Avatar
31x10.50R15 will fit no problem on stock 2wd suspension
accually 32's will fit under a 4x4 stock
The stock 235/75R15 look to small for our trucks, the 31's fill the wheel well nice, and don't rub at all.
We have used this size as a recommendation if changing 4 tires on these style trucks for years at our shop
Duro
-1986 K10 LWB, 350 HD,TH400
3.08, 30 spline 10 bolt, with an Auburn Posi, 31" tires
All original, second owner truck
-1979 Monte Carlo, 350, 200r4, 3.73 posi
-1987 GT T-top Mustang - slow moving project
Duro5341 is offline   Reply With Quote
Old 04-06-2007, 10:11 PM   #4
Srubydo1986
The Crazy Machanic
My step dad keep saying the wieth is to much is he just blowing smoke or is he right?
He says he had a 2wd and tryed putting 31 under it and it rubbed the frame. I think hes truck my have sat lower then mine cause with my old black c10 i think the springs were way wore out cause it sat about 2-3 lower in the front and rear.
Also i used it to haul about 7500 pound about 5 times Kinda killed that truck. This one will be treated much nicer, black one was my first pickup and thought its a truck it can do anything well i was wrong gotta have the right stuff first.
newest additions
Old 04-07-2007, 05:27 AM   #5
Ivan D.
glamoros piece o' lowlife
Ivan D.'s Avatar
You might have seen it already, but here's a side shot of my '79 C10, suspension is so stock all paint's turned into rust (literally):
These are 32x11.5x15 in the front, and 33x12.5x15" in the rear, there's no rubbing whatsoever. And what yer dad said about the weight being too much - what weight is too much?
The more I drink, the more I drink, the more I drink...
diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express
Ivan D. is offline   Reply With Quote
Old 04-07-2007, 11:49 AM   #6
garysouthlake
'lox'
garysouthlake's Avatar
I have 275 x 55 x 20's on stock suspension (31.7" diameter) and they clear.
garysouthlake is offline   Reply With Quote
Old 04-07-2007, 02:13 PM   #7
Srubydo1986
The Crazy Machanic
thoought id show you what the tires look like. Would have liked to used the rims but they are 6 lug and mines a 5.
And hers a pic of my truck before motor installed. didnt go down much.
These have the stock rims im going to use i need newer pics but no film.
newest additions
Old 04-07-2007, 08:16 PM   #8
Srubydo1986
The Crazy Machanic
and heres a more resent picture
newest additions
Old 04-08-2007, 07:47 PM   #9
benoit454
Chris
benoit454's Avatar
I ran 2 sets of 31x10.50's on my 76 with no rubbing at all. One were mud tires, the others were street tires.
I also ran 3312.50's on a stock 86 4x4 so 33's will fit 4x4 and 31's fir 2wd for sure I had it that way. If they rub you got something wrong, worn springs or something.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 04-08-2007, 08:51 PM   #10
Srubydo1986
The Crazy Machanic
ok thing that saves me about 250 for 2 tires fo know atleast.
newest additions
Old 04-08-2007, 10:18 PM   #11
SmittySmith
'82 GMC Sierra Classic
SmittySmith's Avatar
I've been running 31X10.50's on my 1982 GMC Sierra Classic 1/2 ton stock suspension with 15X7 rallies and have plenty of clearance, no rubbing whatsoever. Not exactly a low rider with those 31's, has worked great for haulin and towin....
~ Smitty
SmittySmith is offline   Reply With Quote
Old 04-08-2007, 10:24 PM   #12
Srubydo1986
The Crazy Machanic
great well mines no low rider either as you can see from the pics
newest additions
Old 04-09-2007, 10:32 AM   #13
neverfinished
I'm running 31x10.50R15 on mine too, it's all stock suspension and no rubbing.
neverfinished is offline   Reply With Quote
Old 04-10-2007, 06:49 PM   #14
Prerunner1982
Prerunner1982's Avatar
I have run both 31x11.50 and 32x11.50 on 15x8s with stock (except HD front coils) and didnt have a rubbing problem with the 31s and only a slight rub with the 32s on the inner fender and upper fender lip. If there is a rub problem it wouldnt be with the frame it would be with the fender.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
