Pickin' and a Grinin'
Drop My Rear end....
I have a 72 GMC 3/4 ton Burb. I want to drop the rear about 2-3" as it sits a lot higher than the front.
I have done an extensive search, but have not found an answer for my application. Is there some different springs I can get? Any other options? I would appreciate any help. Jeff |
![]() Join Date: Apr 2005
Re: Drop My Rear end....
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Looks pretty good, but I will have to call and find out if those drop springs work for my 3/4 ton.
![]() Join Date: Aug 2005
Coil Springs? Not sure if any Burbs were leaf... but if it's coil just get some lowering blocks. Here are some I made back in highschool:
Luv the Crewcabs
Were did u find the longer u bolt's to use?
Thanks, Rick |
Made those too
![]() ![]() Here's one option. I'm sure ECE and even local shops carry them too. |
That looks good, but I have not seen anything that says it will be fine for a 3/4 ton.
I would suppose if it all looks the same between a 1/2 ton and a 3/4 ton, the blocks would be fine. |
