Old 04-06-2007, 10:21 PM   #1
tranz am
tranz am's Avatar
Will this work? 75 5 lug rear end to replace my 69 gmc 6 bolt?
Today I was at the junk yard and found a 5 lug 342 posi under a 75 chevy 3/4 ton flat bed. It seams strange that it was bolted to that 3/4 ton suspension.
I need to know if this can be made to fit under my 69 1/2 ton 2 X4 GMC. I will be going down there tomorrow morning to rip it out if it will work. So this info is urgently needed.
Here are some pics
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=456220
Best 1/4 mile time 12.1 @ 111 w/traction issues
1969 GMC SWB
1964 chevy II Nova ht
tranz am is offline   Reply With Quote
Old 04-06-2007, 10:23 PM   #2
1969k10stepside
Re: Will this work? 75 5 lug rear end to replace my 69 gmc 6 bolt?
You want to put a 5 lug rear in a 1/2 ton?That truck (3/4 ton) shouldnt have had a 5 lug anyway.And no,the shock mounts are different as are the spring perches.It will work with those modifications to make it work on 67-72s though
1969k10stepside is offline   Reply With Quote
Old 04-06-2007, 10:26 PM   #3
tranz am
tranz am's Avatar
No, I want to put it in my 69 half ton.
My build thread
1969 GMC SWB
Old 04-06-2007, 10:28 PM   #4
1969k10stepside
I thought you said it was a K15.K15 means 1/2 ton GMC 4x4.
So,assuming instead it is a 2wd,with leafs....you will need to fab up a set of mounts for springs for the springs still as they are different than ones from a newer model,as are the shock locations.
Old 04-06-2007, 10:31 PM   #5
arkracing
Weekend Warrior
Anything can be made to fit. The spring pads will need to be changed as well as the shock mount - nothing a grinder and welder won't take care of.
You can buy new trailing arm perches/spring perches. - and you can cut the shock mounts off your existing '69
Is your truck 4x4 or 2x4 - cause if it is 4x4 your wasting your time - as there isn't chevy front axle with a 5 bolt pattern
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
