Old 04-07-2007, 08:57 AM   #1
68 P.O.S.
What else should I do?
I'm getting ready to change my oil pan and timing chain cover gaskets soon. Is there anything else I should probably change or fix while I'm in there? The obvious thing is a new timing chain, but what else?
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 04-07-2007, 09:59 AM   #2
70GMCer
70GMCer's Avatar
Re: What else should I do?
How's the oil pressure? Might consider changing the pump. Cheap insurance...Also try using the one piece oil pan gasket from Felpro. A little more pricey, but well worth it.....
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 04-07-2007, 10:05 AM   #3
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Don’t ask me about doing this job!!!lol I started just like that and now my engine is in the shop being built into a 383!
Is you engine out? This will be a lot easier if it is. Do the rear main seal too.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 04-07-2007, 11:05 AM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Yep, definitely a rear main seal too.
