Old 04-07-2007, 11:21 AM   #1
CrashBob1
CrashBob1's Avatar
Late model brakes for my '67 C20
Maybe it's my inexperience with this site but I can't seem to get the search to work for looking up this subject in previous posts.
So here's the question: What year, model components would be best to use for converting to front disc brakes? Money is an object at this time so what's the most economical route?
OR...........is there a later model chassis that I could roll under my body without too much modification.
I am still in the "mental" stages of planning for my truck, so ALL advice and suggestions will be appreciated and considered.
Thanks in advance!
CrashBob
Just when you think you've made it idiot proof, along comes a better idiot.
CrashBob1 is offline   Reply With Quote
Old 04-10-2007, 03:00 AM   #2
royo
royo's Avatar
Re: Late model brakes for my '67 C20
you could find a front end out of 73 -81 aframes rotors calipers. bolt all this in the place of your drum brakes what i found out is the ball joints are a different size where they go in the spindle 67-70 same 71-72 same then 73-81 same the 67-72 also have the 55$pc a frame bushings 73 up 5$ but then what do i know i could be wrong .
nickle and dime
royo is offline   Reply With Quote
Old 04-10-2007, 10:23 AM   #3
CrashBob1
CrashBob1's Avatar
I think I understand everything except what is 55$pa a frame? The 73-81 will just bolt up then, that's good to know.
Old 04-10-2007, 11:42 AM   #4
Tony@AirRideTech
Junior Member
Actually, you should only need to boneyard you a set of spindles and brake calipers. Then when you get your new ball joints, just get them for the year of truck that the spindles came off of.
Tony@AirRideTech is offline   Reply With Quote
Old 04-10-2007, 02:33 PM   #5
CrashBob1
CrashBob1's Avatar
Isn't there supposed to be a proportioning valve somewhere in the mix? Also, will my current mastercylinder and booster work?
So many questions...........so few answers
Old 04-10-2007, 08:11 PM   #6
royo
royo's Avatar
its the stock a frame bushings for 67-72 55$ pcs sorry
nickle and dime
Old 04-10-2007, 08:12 PM   #7
royo
royo's Avatar
parts parts doner truck
nickle and dime
Old 04-11-2007, 08:26 AM   #8
CrashBob1
CrashBob1's Avatar
Got it. fortunately, I am friends with the local boneyard operator and now that I know what I need, it's off to the iron pile.................ya hoooo!!
