Old 04-07-2007, 02:34 PM   #1
tim123104
stupid question??
I think I know the answer, but want to be sure. How bad is it to run 2 different gears on a 4x4? 3.73 rear 3.43 front. Its only going to be for a short time untill i can change the ball joints on the matching rear.
tim123104 is offline   Reply With Quote
Old 04-07-2007, 02:36 PM   #2
snj8198
snj8198's Avatar
Re: stupid question??
just don't use 4 wheel drive till you change gears.
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 04-07-2007, 06:08 PM   #3
Eichorst69
It's not a good idea! BUT, I did it once when I tore up my 4.56 rear. I stuck a 4.10 in and ran it with the 4.56 front until i was able to find a 4.56 Eaton rear. You could tell there was a strain on the drivetrain and I had to fight to get it out of 4 wheel.
Rob
Eichorst69 is offline   Reply With Quote
Old 04-07-2007, 06:38 PM   #4
msgross
msgross's Avatar
If you have the hubs unlocked and the T-case in 2Wd then no worries......but I wouldn't dare try it unless I was on pure snow or deep mud. I have heard that 3.07/3.08 isn't an issue but I wouldn't go further than that spread.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 04-07-2007, 08:09 PM   #5
LONGHAIR
I am interested in the ball-joints in a rearend?
LONGHAIR is offline   Reply With Quote
Old 04-07-2007, 10:21 PM   #6
msgross
msgross's Avatar
some people call any axle a "rear"... front or rear
I assume that his matching gear front axle needs the ball joints....
I wouldn't hook up the front driveshaft if it were me...
The Garage:
Old 04-08-2007, 01:49 AM   #7
454_72_4X4
454_72_4X4's Avatar
My wife's 80 has 4.09 front/3.73 rear right now. It's been that way for a couple years. Waiting on one of those roundtoit's to swap the front to 3.73's also.
3.07/3.08 is probably a factory setup, but I'm not sure. I do know 3/4 tons that have 4.10 rear gears, have 4.09 front gears. It's a designed in "lead" so the rear is less prone to try to pass the front in low traction conditions.
IE fishtailing in mud/snow/etc.
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 04-08-2007, 08:28 AM   #8
Mudder
Mudder's Avatar
A lot of mud racers will use a "little" higher gear in the front, but I wouldn't recommend doing it just out 4wheeling. Never on the road.
Mudder is offline   Reply With Quote
Old 04-08-2007, 09:29 AM   #9
You can compensate with tire diameters.I just wouldn`t use 4wd at all.
I`m swapping the rear in my`92 work truck and the replacement is a 3.73.Once I get the original rear out,I`ll pull the 4.10 R&P,run it to my mechanic,and have him swap that out.I can`t have the truck down more than a day and I don`t want to pay him to do the whole job.
Old 04-09-2007, 12:52 AM   #10
Zoomad75
K5Camper
Zoomad75's Avatar
To avoid breaking something I'd follow Msgross's suggestion. Leave the front driveshaft out. This way even if some how you manage to forget and shift the t/case from 2hi to 4hi or 4lo, you won't grenade the t/case.
I would say this though. If the front is just needing ball joints, why swap the whole axle out to fix it? Seems like it would be easier just to change the ball joints to me. Then you don't have to worry about the mis-matched ratios.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 04-09-2007, 01:50 AM   #11
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
I was just going to point out and ask the same question?
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 04-09-2007, 10:00 AM   #12
I was just responding to the different ratio question.Whoa!Now that I read the queastion,Zoomad`s is right.Don`t pull that axle to do ball joints,no need.
Old 04-09-2007, 05:51 PM   #13
tim123104
I was just trying to save some time and money. Getting alittle lazy!!!
Old 04-09-2007, 07:37 PM   #14
LONGHAIR
Wow, I certainly didn't get that out of the first post. I guess it's because I would never consider swapping an entire axle housing to get less used ball-joints. They aren't that hard to change. They are not very much money either.
Old 04-09-2007, 07:54 PM   #15
Zoomad75
K5Camper
Zoomad75's Avatar
No big deal. I'm lazy too, but I'd much rather deal with ball joints than wrestle a heavy axle out to only do it again later once I got my butt in gear to do the ball joints.
Sometimes I have to get motivated to get stuff done. go rent the ball joint press and get to work!
Rob Z.
Old 04-10-2007, 04:38 PM   #16
tim123104
Yea thats the way im going. Thanks for the modivation!!
Old 04-15-2007, 08:56 PM   #17
Stano
Stano's Avatar
Yeah I wouldn't put in 4x at all. I do however have one of the sets of 3/4 ton axles with 4.09's in the front and 4.10's in the rear. I am refurbishing them and putting them in my crew cab project.
New daily driver 96 Chevy K3500 crew cab dually 53,000 miles 350 Vortec 4L80
Nice ride 67 Chevy C-10 LWB Built 350 TH-400
Wifes ride and family rig:
2001 Furd Expedition 5.4 Liter
Kickin back in Rolla,Mo. USA
"Do the thing you fear most and the death of fear is certain" Mark Twain
Stano is offline   Reply With Quote
Old 04-16-2007, 01:26 PM   #18
Zoomad75
K5Camper
Zoomad75's Avatar
4.09's and 4.10s are close enough that the ratio mismatch isn't and issue. If I did my math right its around 1/4 of a percent different. Whereas, the original example of 3.73's and 3.42's is an 8 percent difference in ratio. That's a big jump in ratios.
Most of the GM 4wd's that were equipped with 4.10s had the same difference in ratios. That small of difference won't hurt anything.
Rob Z.
