Old 04-07-2007, 04:45 PM   #1
EAST SIDE LOW LIFE
EAST SIDE LOW LIFE's Avatar
Help .... Where Does This Part Belong?
Ok, when I ordered these I was told that they were inner fender dust shields, and that they come with staples to attatch them. I thought that they were to go between the inner fender wells and the frame as other Chev vehicels that I've seen.. They do not appear to.
My question is this .... has any one used these and if so where do they go?
Thanks,
esll.
Tomorrow is for doing today's stuff.
This truck has just the right amount of energy for me!
Author: Warren Lake .... (member)
EAST SIDE LOW LIFE is offline   Reply With Quote
Old 04-07-2007, 05:10 PM   #2
72 CustomCamper
huh ???
72 CustomCamper's Avatar
Re: Help .... Where Does This Part Belong?
LMC shows that they go between the fender and cab just in front of the door hinges...
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 04-07-2007, 05:11 PM   #3
CPNE
Resident Curmudgeon
CPNE's Avatar
Open your door an look in where the hinges attach to the cab. Those pieces are designed to go vertically inside your front fenders where they meet the door. They seal the gap between the fender and the cab, presumably to prevent wind and noise entering the cab.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 04-07-2007, 06:50 PM   #4
EAST SIDE LOW LIFE
Thanks guy's .... lesson learned, when your buying parts don't believe every thing your told.
esll.
Old 04-07-2007, 08:35 PM   #5
72CSTC5
72CSTC5's Avatar
They bolt to the "a" pillars of the truck.
72CSTC5 is offline   Reply With Quote
Old 04-07-2007, 10:46 PM   #6
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 04-08-2007, 10:42 AM   #7
EAST SIDE LOW LIFE
Originally Posted by BobbyK View Post
Now that's help full, getting them installed should be fun. Oh well to live is to learn .... thanks Bobby will go out and take another look at it.
esll.
Old 04-08-2007, 10:42 PM   #8
BobbyK
BobbyK's Avatar
Pretty much impossible to install with the fender on.
They are held on with sheet metal brackets.
Pain in the butt to put together too.Unless you have a stapler large enough for the large staples that come with the fender gaskets.
