Old 04-07-2007, 05:53 PM   #1
superhondaz50
superhondaz50's Avatar
Hi, new here, need help with a drop... Clearance
Hi, my name is Ryan and i'm fixing up a 69 c-10. This truck belonged to my best freind. He was recently killed while riding a motorcycle, and his father gave me this truck. I want to fix it up as a tribute to him. So my question is... how low do you think I can drop this truck? It has full length headers so i'm worried about ground clearance. If I can I would like to use 2.5 spindles in the front and 4 inch coils in the rear,(also what other parts do I ned for this height of drop) if I cant I am thinking about a 1/3 drop with coils.
Thanks for your help!
superhondaz50 is offline   Reply With Quote
Old 04-07-2007, 07:32 PM   #2
powell72
powell72's Avatar
Re: Hi, new here, need help with a drop... Clearance
You'll be fine with a 2.5/4. You'll need spindles, rear springs, and shock relocators. Welcome to the board, sorry to here about your friend, make him proud.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 04-07-2007, 09:26 PM   #3
see ten
WTB this ad
see ten's Avatar
Sorry about your friend. Don't let the exhaust hold you back. If you want it low run some new pipes and tuck em up a bit higher. Looks like he had a good start, I see 5 lug wheels ( I assume there are discs ) and one piece side windows as well. Take your time and look around the site and maybe you'll find a drop you like and can live with.
see ten is offline   Reply With Quote
Old 04-07-2007, 10:10 PM   #4
cdowns
cdowns's Avatar
fine with that drop?? looks to me the exhaust will be right about on the ground with a 2.5/4 drop// you'll need a new exhaust from the engine back//also you need an adjustable panhard bar to center the rear correctly also need would be shock relocaters in the rear and new smaller shocks/// lots of the venders have complete kits to save a bit of money over individual prices
Old 04-07-2007, 10:19 PM   #5
ThatOneBlue67
I survived Dead Man's Curve.
ThatOneBlue67's Avatar
Hi there! I would measure the distance from the bottom of your header's collector to the ground and see if it is singificantly longer than 2.5"
My dad dropped his 67 with drop spindles and he still is rolling around with long tube headers. Just go slow over speed bumps.
Also for dropping the rear, LMC only mentioned needing the adjustable panhard bar if you went 5" or lower. We also did the 4" drop and the bar fits. A little snug, but everything is working out so far.
If I had a friend like you that actually continues and cares for my classic truck, I'd be damn proud. I'm sure you'll enjoy it just like he did.
"The people should not be afraid of their government. The government should be afraid of it's people."
"The Hurricane"
1967 Chevrolet C10
350 Eight Cylinder, 700R4 BowtieOverdrive
Cherry Bomb... Disturbing the Peace Since 1968.
ThatOneBlue67 is offline   Reply With Quote
Old 04-08-2007, 12:19 PM   #6
superhondaz50
Ya it has discs, but that leads me to my next problem, I dont know if he replaced the whole front clip, or just a few parts. how would I be able to identify whats there so I can get the correct parts (spindles and such)
Old 04-08-2007, 09:26 PM   #7
see ten
WTB this ad
see ten's Avatar
Hmmm, don't know but TTT for ya!
Old 04-08-2007, 09:33 PM   #8
centsless
sufficiently talented fool
centsless's Avatar
I would say if it has the discs, then it has the 1971/72 spindles on it. The control arms are the same, they just use a different ball joint. I have full length headers on mine, and the front pipe is under the frame. I have 3/5 lowering springs on mine and have no clearance issues at all. Here is a before and after pic so you can see what a difference it makes.
Attachment 257414
Attachment 257415
"it's impossible to be surrounded by idiots when you are part of the circle"
2003 Suburban
2002 Pontiac Montana
1981 Corvette
1966 Impala Convertible
Click here to support the board
centsless is offline   Reply With Quote
Old 04-08-2007, 11:45 PM   #9
powell72
powell72's Avatar
I had a truck with the exhaust done the same way with a 2.5/4 drop and never had any issues. You really don't need an adjustable panhard with a 4'' drop, it wouldn't hurt, but it's not needed.
Chris
