Old 04-07-2007, 07:15 PM   #1
Rob1000
Rob1000's Avatar
Will A 3/4 Drop Level My Shortbed???
I'm trying to figure out if a 3/4 drop will level my truck out. I want the front slightly lower than the back. What lowering kits do you reccomend?
Rob1000 is offline   Reply With Quote
Old 04-07-2007, 08:12 PM   #2
short69
short69's Avatar
Re: Will A 3/4 Drop Level My Shortbed???
a 3/4 drop should leave the front about 1 inch lower.usually thare needs to be a 2 inch difference to level it out.
69 shorty w/ 67 front clip
short69 is offline   Reply With Quote
Old 04-07-2007, 08:29 PM   #3
scrapmetalart
Junior Member
Do you have a tape measure?????
frontstreetcycle on Instagram
scrapmetalart is offline   Reply With Quote
Old 04-07-2007, 08:33 PM   #4
centsless
sufficiently talented fool
centsless's Avatar
I agree, use a 2/4 or a 3/5 drop. Front spindles and rear blocks will retain your ride quality. Springs are a little cheaper, but you do lose some ride quality.
"it's impossible to be surrounded by idiots when you are part of the circle"
2003 Suburban
2002 Pontiac Montana
1981 Corvette
1966 Impala Convertible
Click here to support the board
centsless is offline   Reply With Quote
Old 04-07-2007, 08:50 PM   #5
cdowns
cdowns's Avatar
for best results theres nothing like measureing the height of your front and rear bumpers subtract the front from the rear and thats how much more you need to drop the rear for it to sit leval
Old 04-07-2007, 10:30 PM   #6
Rob1000
Rob1000's Avatar
Thanks for the positive information. Oh yea, I do have a tape measure but I wanted to know how much of a drop I need from my trucks original ride height, not the height of it now with springs that are 35 years old and possibly have some sag...scrapmetal. Thanks anyway
Old 04-07-2007, 10:34 PM   #7
71see10
Worthless
71see10's Avatar
I used a 2 1/2 drop spindle and a 5" drop spring in the rear,Left the back of the truck just a little higher.I also wanted the level look,without looseing my ride.This worked, can't tell the difference from stock and it dosen't bottom out.
71see10 is offline   Reply With Quote
Old 04-08-2007, 10:50 AM   #8
I think the rears originally sat a good 3-4 inches higher.
Old 04-08-2007, 01:01 PM   #9
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Editorial comment on stepside lowering (for cultural enrichment only). I dropped my stepside as low as I could go with bags and springs. I just wanted it "level" with the tires even with the top of the wheel opening. Same size tires/wheels front and rear. I put the rear tire level with the rear wheel opening and front still had about 1+" to go. I put a level on the bed and the truck has a forward rake! I believe the wheel openings are designed to give the truck a forward rake so having it level may give it a nose up look.
Anyone else notice this with the fleetsides or are they different?
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 04-08-2007, 09:24 PM   #10
see ten
WTB this ad
see ten's Avatar
Yep the fenderwells are a different shape. The fronts have to have room for the tires to move side to side while moving up and down while the rear tires only have to go up and down. My K10 looks like it's slightly squatted in the rear (like most 4x4s do) but when I put a level on the bedside she has a forward rake!
see ten is offline   Reply With Quote
Old 04-08-2007, 09:58 PM   #11
lamar
lamar's Avatar
If you get in touch with Early Classic they can give you the measurments for factory height ( before 30 years of use) then you can figure out how much lower you want the front and the back. That will tell you exactly what drop you will need. Hope that helps.
72 C-10
lamar is offline   Reply With Quote
Old 04-08-2007, 11:13 PM   #12
st1x10
st1x10's Avatar
LMC has the stock heights in their catalog.
1970 Chevy C10 "Under Construction"
2002 Chevy S10 V6
st1x10 is offline   Reply With Quote
Old 04-09-2007, 01:23 AM   #13
stllookn
stllookn's Avatar
see ten, I guess I will just end up tucking both tires a bit and be happy with the forward rake.
Old 04-09-2007, 02:55 AM   #14
Rob1000
Rob1000's Avatar
On the rear of my truck I have three coils on both sides that are stuck together. Is that because they were heated or is it normal?
Old 04-09-2007, 06:31 AM   #15
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Quite normal for old sagged springs.
Old 04-09-2007, 09:04 AM   #16
N2TRUX
Happy to be here
N2TRUX's Avatar
I assume that supposed to mean if he measured now he would know the answer.
Unfortunately that is not the case since there are so many variables in lowering a truck. Just because it's "advertised" as a 3-4 drop doesn't mean your going to get exactly 3" front and 4" rear.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
