Old 04-07-2007, 09:12 PM   #1
clay68c10
clay68c10's Avatar
Question Parts store guru question
I have been looking for the right carrier bearing and I'm having no luck with any of the usual resources from NAPA/AZ/Oreilly. They all show the same PN carrier bearing and it doesn't match what I have. I also checked some of the site vendors and I'm not seeing anything there.
I've done a few carrier bearings on 1/2 ton trucks and I've never ran across the type I have now. Ususally it is the 2 bolt flat carrier or the light duty small type.
Did the BBC trucks come with a 3/4 ton part? Of course, no one has the 3/4 ton part in stock for me to compare. The pn that keeps coming up is HB88107A. The bearing inside dia is correct (1.378), but the carrier is totally different.
Here's some pix if that helps.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 04-07-2007, 09:19 PM   #2
cdowns
cdowns's Avatar
Re: Parts store guru question
last time i got a carrier bearing at carquest thats the one they got me on the first time
Old 04-08-2007, 01:29 AM   #3
clay68c10
clay68c10's Avatar
Any idea what application it was for?
13 Tahoe LTZ
Old 04-08-2007, 02:44 AM   #4
oldiron
Designated Grumpy Old Man
oldiron's Avatar
You might try a driveline shop.
oldiron is offline   Reply With Quote
Old 04-08-2007, 03:05 AM   #5
GREASEMONKEY72
GREASEMONKEY72's Avatar
or a tranny shop to
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 04-08-2007, 09:41 AM   #6
boot85
71 Chevy
I have that same type on my 1/2 and 3/4 ton trucks. The 1/2 ton is a four speed and the 3/4 ton is an automatic, both are 2WDs. I am about 99% sure that both are the original carrier bearings. I have been wondering if any one else had this type because all I ever see or hear about on this site are the lighter duty ones. I haven't seen anybody complaining about this style carrier bearing so maybe they are a lot more durable than the other style.
71 C10
72 C20
62 Chevy II 2DR HT
boot85 is offline   Reply With Quote
Old 04-08-2007, 09:54 AM   #7
truckdude239
truckdude239's Avatar
http://www.partsamerica.com/ProductD...pe=907&PTSet=A
thinki this is what you need i looked it up for a 1968 c-10 with 396
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 04-08-2007, 11:17 AM   #8
clay68c10
clay68c10's Avatar
Thanks truckdude, parts america is one place I didn't look, I like the way it gives you measurements for the whole assambly and not just the shaft size. I'll have to go measure what I've got and see if it matches.
13 Tahoe LTZ
Old 04-08-2007, 01:42 PM   #9
clay68c10
clay68c10's Avatar
Close, but not quite the same. The distance between the x-member mounting bolts is just shy of 6 inches and there are 4 bolts instead of 2. It may be driveline shop time. Thanks for all the help so far.
13 Tahoe LTZ
Old 04-08-2007, 03:13 PM   #10
cooters
might be a leaf spring bearing, i cant see how that bearing would fit into the trail arm xmember
cooters is offline   Reply With Quote
Old 04-08-2007, 03:38 PM   #11
clay68c10
clay68c10's Avatar
It's definitely different that any of the ones I've seen before. The truck is a factory coil rear and the riveted braket that holds the bearing to the x-member appears to be original and has only one bolt pattern with 4 holes. If I wasn't driving it everyday right now, I'd just pull it apart and search some driveline shops with it in my hands. It's not too beat up or rough, thankfully. I just figured I'd replace it while I was in there doing the u-joints.
13 Tahoe LTZ
Old 04-08-2007, 03:59 PM   #12
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
that's the style my one ton had, it's not made any more. I just went to a drive shaft shop and they gave me one that is dirt cheep and beefy as hell. I did have to take some flat stck, bolt it to the X-member and then botl the bearing to it, but it all works great with no vibrations or anything.
Old 04-08-2007, 05:47 PM   #13
clay68c10
clay68c10's Avatar
Cool, thanks for the info LM. I wondered if I was dealing with an updated/discontinued part type issue.
13 Tahoe LTZ
