Old 04-07-2007, 10:09 PM   #1
underdog8704
NCStroker
underdog8704's Avatar
Wires and Looms-
hey fellas, im looking for some opinions on spark plug wires and looms. im running heddman headers, and the #5 plug wire keeps getting burnt on the header. a part of that is the crap looms that were on there now. im just looking for some opinions on looms or even a better way to keep this from happening. thanks alot. _matt
1971 Chevy C/10-Built 383 Stroker
underdog8704 is offline   Reply With Quote
Old 04-07-2007, 10:23 PM   #2
71see10
Worthless
71see10's Avatar
Re: Wires and Looms-
I'm also running headman (elite) headers,These are the looms I just Installed. So far they are working great,gets the wires out of the way.Hope the pics helps!!!
71see10 is offline   Reply With Quote
Old 04-07-2007, 11:00 PM   #3
xmitsu10
xmitsu10's Avatar
Sounds too familiar. Does your #1 pipe run over and behind the #5 pipe? My Hedmans do the same. I must have burned 3 wires/boots before I finally got something to work.
I purchased an MSD high-temp boot like this (http://www.msdignition.com/wire_4.htm). I then covered the wire with a heat protection sleeve that slide over the wire. I then covered the boot and wire with a fiberglass boot protector like this (http://store.summitracing.com/partde...5&autoview=sku).
I just ordered a set of new shorty headers from ECE that should eliminate my boot/wire problems this year (I hope).
Mark
71 Cheyenne SWB
xmitsu10 is offline   Reply With Quote
Old 04-07-2007, 11:06 PM   #4
underdog8704
NCStroker
Originally Posted by xmitsu10 View Post
Sounds too familiar. Does your #1 pipe run over and behind the #5 pipe? My Hedmans do the same. I must have burned 3 wires/boots before I finally got something to work. Mark
Thats what my problem is. The number 1 pipe leaves very little to play with as far as wires. I would love to figure out a way to run the wires under the headers, but ill have to see about that.
Old 04-08-2007, 11:21 AM   #5
xmitsu10
xmitsu10's Avatar
There is one other thing you can try (if you haven't already). Header spark plugs because they are shorter, it will give you a little more room for the boot and wire.
71 Cheyenne SWB
Old 04-08-2007, 11:32 AM   #6
rage'nrat638
rage'nrat638's Avatar
how about some pictures of center bolt wire loom options too
rage'nrat638 is offline   Reply With Quote
