Old 04-07-2007, 10:32 PM   #1
ThatOneBlue67
I survived Dead Man's Curve.
ThatOneBlue67's Avatar
Question Chopping coils
Ok, now I'm prepared to receive tons of negative feedback on this subject. BUT, I have to ask.
Is cutting coils really THAT bad?
I'd like to see my truck lowered, and I was hoping to spend my tax return money on it. But now I've got bills, high gas prices, and the union screaming at me for more money. I'm definetly going to do drop spindles and such in the future, but right now I'm a broke kid getting ready to graduate high school.
If I just cut 1-1.5 inches off the front coil (with a hack saw or similar) and 2 or 3" off in the back, would anything bad happen? By bad I mean: premature wear on neighboring parts, broken shocks, stuff falling off on the freeway, crappy suspension travel, etc.
Just asking, I haven't actually done it yet. Would like to hear everyones views. Thank you guys.
"The people should not be afraid of their government. The government should be afraid of it's people."
"The Hurricane"
1967 Chevrolet C10
350 Eight Cylinder, 700R4 BowtieOverdrive
Cherry Bomb... Disturbing the Peace Since 1968.
ThatOneBlue67 is offline   Reply With Quote
Old 04-07-2007, 10:36 PM   #2
72armyswbtruck
72armyswbtruck's Avatar
Re: Chopping coils
Why not just flip them?
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 04-07-2007, 10:36 PM   #3
dave2953
Dave's not here, man
dave2953's Avatar
Re: Chopping coils
I cut my front coils about 3 years ago and haven't had any problems, i.e. no irregular tire wear, front end parts, etc. I cut 1.5 coils off mine. I wouldn't recommend cutting off that much because when I go over bumps the springs bounce around in the pocket. As far as the rears, you can't cut the rears since they are pigtailed at the cups. I replaced mine w/ drop springs. There was a really good thread concerning the pros and cons a couple of weeks back; I'll see if I can find it.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 04-07-2007, 11:01 PM   #4
ThatOneBlue67
Re: Chopping coils
Cool cool, yeah I noticed the rear coils had an inconsistent design.
"The Hurricane"
1967 Chevrolet C10
Old 04-07-2007, 11:57 PM   #5
70c10
67-72 Addict!
70c10's Avatar
Re: Chopping coils
I cut 1.25 coils off mine and got almost 3" drop on the front. The coils are now on Captain Keneival's truck and look great!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 04-08-2007, 12:19 AM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Chopping coils
use a cut off wheel or a torch, if you ue a hack saw, it'll take all weekend and you'll spend $200 in blades.
Cutting them is fine. That's how it's been done for 50 years untill the 90's when they actually started making lowering springs.
Old 04-08-2007, 10:05 AM   #7
Boog
laying low
Boog's Avatar
Re: Chopping coils
There are many threads about lowering our trucks and many have cut front coils. There are drawbacks of course. But if you go that route use a cutoff wheel and take maybe 1 round off the fronts and use a 2" lowering block on the rear. This is about as cheap as you can do it.
Do not simply heat the springs to lower it!
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 04-08-2007, 10:54 AM   #8
centsless
sufficiently talented fool
centsless's Avatar
Re: Chopping coils
I have heard that you can put the spring in a bucket of water with about one coil out of the water and heat them. The water will keep the rest of the spring from getting hot. I honestly dont really see a big difference between cutting a coil, and lowering springs. Definately put the correct shocks on, so it will prevent the spring from coming out of the pocket. Also, look around, I found my 3/5 springs on e-bay for $100 shipped. They also show up here on the board on occasion.
"it's impossible to be surrounded by idiots when you are part of the circle"
2003 Suburban
2002 Pontiac Montana
1981 Corvette
1966 Impala Convertible
Click here to support the board
centsless is offline   Reply With Quote
Old 04-08-2007, 11:06 AM   #9
crazy longhorn
Fabricate till you "puke"
Re: Chopping coils
To locate properly top/bottom, you are best to stick with 1 round off the front coils. This also keeps the spring from bouncing around in the pocket, like you get with shorter coils. My truck was done this way, as a temporary deal about a dozen yrs ago. It hasnt caused any problems.....& likely will stay that way("if it aint broke, it dont need fixin") I did build a set of shock relocators, to get the shock in the middle of its travel. best of luck L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 04-08-2007, 12:46 PM   #10
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Chopping coils
From experience with MANY lowered vehicles this is 100% correct. Cut a spring with low heat and you will be just fine. Heat a spring until it collapses and it will continue to sag till it hits bottom
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-08-2007, 12:58 PM   #11
65-72 chevytoys
65-72 chevytoys's Avatar
Re: Chopping coils
Best to use a cutoff wheel. Is faster than a hacksaw and doesn't change the spring rate from too much heat by using a torch.
2004 Chevy Silverado 1500LS SWB 5.3L
2004 Corvette Z16 #770
Wish I had not sold 72 blazer
65-72 chevytoys is offline   Reply With Quote
Old 04-08-2007, 10:11 PM   #12
ThatOneBlue67
Re: Chopping coils
OK ok cool. Thankyou everyone! I've got the enxt week off from work and school ,so I'll see what I can do.
"The Hurricane"
1967 Chevrolet C10
