Bite me, import boy
Automatic transmission linkage
I have a Turbo 350 from a 71 installed in the 65. It had originally had a T350 before I got it, although I'm not sure if was original or not. The original column showed a 3 speed auto.
What I am needing is a picture of the linkage that mates the original column to the transmission at the lower end, as well as the linkage on the transmission itself. Thank you, Jason
Jason '71 C-10 Deluxe-under construction '69 C20, 396,T400-donor truck, '65 C10 project "Facts are meaningless, You can use facts to prove anything that's even remotely true." |
Bite me, import boy
Re: Automatic transmission linkage
bump
Anyone?
C10 now is a GMC
Jason,
My '62 was originally a "3 on the tree" (manual trans), and when I dropped in a 350sbc & TH350 trans, I used an aftermarket shift rod linkage kit to hook up to shift the trans. You can pick this up at most aftermarket parts suppliers, and is found pretty easily at car shows/swapmeets. ![]() ![]() Then bolt on the little ribbed knob on the shifter arm on the side of the trans, loosely slide on the "arm" on the knob of the shifter arm. Then loosely koo the rod from the steering column down to the "arm on the side of the trans. There is a 2 section on the arm that is slit so that you can fine tune the firmness, or softness of the shift when shifting gears. Once you got everything set the way you want it, tighten everything all up, and you are good to go. ![]() ![]() David
*1962 C10 swb fleetside, big window, custom cab 350/TH350 combo...Hot Rod *1963 C10 lwb fleetside, small window 230/4 speed...Blvd Cruiser *1931 Ford 5 window coupe (soon to be Hot Rod)... Father & Son project |
Bite me, import boy
Thanks for the advice. I will look into one of those kits.
Jason
