04-08-2007, 04:28 AM | #1 |
Airline and heat?
I am wondering how close an DOT airline can be to my exhaust, in one area it will be 4" from the exhaust pipe. Is that to close or will the airline take the heat? Thanks, Mike
85 short, bags,4-link and sway bars |
04-08-2007, 11:12 PM | #2 |
Happy to be here
Re: Airline and heat?
No, it will not take the heat. I have had to lines blow and both times it was from being to close to a heat source. It "might" be safe if you put a piece of rubber hose over it.
04-08-2007, 11:18 PM | #3 |
Commander Taco Bello
what is the recommended space to keep between air lines and exhaust?
04-09-2007, 09:43 AM | #4 |
Happy to be here
My suggestion would be "nowhere near" the exhaust. The last line I had blow was because the exhaust pipe pulled out of the catalytic converter. It was blowing hot air toward the line and caused it to blow.
Anything that can be done to prevent routing airline away from the exhaust is money in the bank.
04-09-2007, 09:50 AM | #5 |
If it has to be routed near your exhaust, create some type of heat shield that's mounted solid. After the heat shield, put the lines in a temp resistant 'sleeve', similar to what is used on spark plug boots.
04-09-2007, 11:35 AM | #6 |
i have mine somewhat near my exaust but i slid a bigger piece of airline over the sections near the heat...
04-09-2007, 05:40 PM | #7 |
Thanks for all the advice! It also gets me wondering how everyone is routing their airline? Im trying to keep them inside the frame rail but when i get to the front i cross paths with my exhaust-which also gets me wondering- is it advisable to run airlines on the outside of the frame towards the top? Looks like the lines would be mostly out of harms way. Whats your thinkin? Thanks Mike
85 short, bags,4-link and sway bars Last edited by DOOBZ; 04-09-2007 at 05:42 PM. Reason: spelling |
04-09-2007, 06:25 PM | #8 |
My lines run along the inside and are at least a foot away from my exhaust just about everywhere. The one spot that crosses over is attached to the crossmember that holds my carrier bearing and I ran them as close to the top of the as I could.
<edit> my exhaust is nothing more than straight pipes off the headers down either side of the drive line and end just past the trailing arm crossmember. Very ghetto, but functional until I get it redone.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 Last edited by jimmydean; 04-09-2007 at 06:27 PM. |
