Old 04-08-2007, 12:43 PM   #1
msgross
msgross's Avatar
FS 4x4 Dana44 parts - PA
I have a few dana 44's still, gears, tie rods, knuckles or other parts available for shipment. Prices are always OBO + shipping....
3.73 gears w/carrier and pinion w/yoke - $100
other gears $50
knuckles - $40
flattop knuckles - $125
axle shafts - $25ea
1/2 brake backing plates - $40
2WD steering box - nice $75
other items available
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 04-08-2007, 01:23 PM   #2
454_72_4X4
454_72_4X4's Avatar
Re: FS 4x4 Dana44 parts - PA
Replied to your PM.
I might be interested in a set of axle shafts though. Is this inner, outer, or both? I know my 44 has one destroyed axle yoke. I'll take a look at it and let ya know.
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 04-08-2007, 02:15 PM   #3
msgross
msgross's Avatar
I have all of the axle shafts for the axles you see. The black one had a needle bearing going out in the spindle and left a few marks on the driver outer shaft. No gouges just marks..
The Garage:
Old 04-08-2007, 08:22 PM   #4
chipflyer
chipflyer's Avatar
Will you go $50 shipped on the solid tie rod?
Sent you a PM
Than you
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen.
1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets!
1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241.
chipflyer is offline   Reply With Quote
Old 04-08-2007, 09:04 PM   #5
msgross
msgross's Avatar
Sure Jeff,
PM sent
The Garage:
Old 04-08-2007, 11:03 PM   #6
va_tlc
va_tlc's Avatar
msgross are you selling anymore of the tie rods? or you selling the whole thing toghther? im in need of one for a 72 3/4 thanks i may be going to carsile. or maybe we could meet somewhere how far off 81 are ya i come thru there each nite thanks
1969 rs
1966fastback
1969swbc/10
2006gt
1972swb4x4
va_tlc is offline   Reply With Quote
Old 04-08-2007, 11:51 PM   #7
msgross
msgross's Avatar
I live about 15 miles from I-81 and hwy 934. I do have others, do you have measurements (tie rod end bolt to tie rod end bolt)?
The Garage:
Old 04-09-2007, 04:42 AM   #8
va_tlc
va_tlc's Avatar
i didnt make it to the shop yesterday ms i will try today and get the measurments thou are they good and straight with the ends on? thanks what shift do u work i come thru there pretty early in the morings around 5 30 or 6 i belive thanks
1969 rs
1966fastback
1969swbc/10
2006gt
1972swb4x4
Old 04-09-2007, 08:08 AM   #9
msgross
msgross's Avatar
I have one ready but the tie rod end bolt (ball joint style?) had two threads messed up. I think it could be easily fixed if you want it cheap.
I work 8am - 4 30 pm weekdays but we could work something out.
Mike
The Garage:
Old 04-10-2007, 02:13 PM   #10
va_tlc
va_tlc's Avatar
how do ya think the threads can be fixed? id be interested if it can be fixed i really apprecate ya time, check an see if it works and name a price i will def go by my brothers wed and check it all out thanks msgross, whick exit are you at? cant member which one there working on at the moment thanks again
1969 rs
1966fastback
1969swbc/10
2006gt
1972swb4x4
Old 04-10-2007, 03:26 PM   #11
msgross
msgross's Avatar
A tap and die set could be used to clean up the bum threads. Not sure but you might be able to press a new tie rod end on it as well. I work at I-81 and hwy 934 at Ft. Indiantown Gap, PA. You can have it for $20 if that helps. It will still have the sleeve and other tie rod end as well.
The Garage:
Old 04-10-2007, 07:51 PM   #12
onetonk5
Cereal Killer
onetonk5's Avatar
A small file coule be used to clean up the male threads. I would guess(since i have bought) that a tap or die would be more expensive than a new tie rod end.
If I dont do it....somebody else will.
onetonk5 is offline   Reply With Quote
Old 04-10-2007, 07:57 PM   #13
msgross
msgross's Avatar
true, it's only two threads on the end as well. I figured if a fella has access to a tap and die that it would clean it up as well.... You might even be able to force the nut on too.
Mike
The Garage:
Old 04-10-2007, 08:02 PM   #14
msgross
msgross's Avatar
Pics For Chipflyer
Here are pics of my 68 tie rod, from the closed knuckle dana 44. You have my paypal addy...thanks
Just realized how small the font was..oops you can see the tape measure, first pic was shaft only, 2nd was end to end total length and third show the corosion that I talked about. I drove this truck around my neighborhood before the resotration started and the steering felt very tight. THanks..
The Garage:
Old 04-11-2007, 10:33 AM   #15
va_tlc
va_tlc's Avatar
mike that sounds good i dont have yr pay pal addy thou, i was thinking you was talking bout the actual tie rod having bad threads, now that i read better i understand its the end with the bad thread, thats fine i have one new end one mine its my actual tie rod the rod thats bent on the end, are you going to carsile i pretty sure ill go sat but if for some reason i cant how would be best for you? thanks tony
1969 rs
1966fastback
1969swbc/10
2006gt
1972swb4x4
Old 04-11-2007, 10:44 AM   #16
1969K10
1969K10's Avatar
Is that closed knuckle 6 or 8 lug? if it's 8, do you still have parts to convert my 6 lugger to 8lug?
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 04-11-2007, 10:53 AM   #17
msgross
msgross's Avatar
va tlc: i'll be going to Carlisle but was planning on going on Friday. I could meet you in Harrisburg saturday if that helps. Don't worry about paypal, cash on delivery will work.
1969K10 - I only had that parts to change an open knuckle to 8 lug, it's gone now though. I will look for a Dana44 8 lug or Dana 60 for you though. I would swap entire axles and go for disc brakes myself, actually i'm doing just that.
The Garage:
Old 04-11-2007, 01:04 PM   #18
va_tlc
va_tlc's Avatar
ok mike i measured mine jus now and its 51 1/4 so that should match pay on delivery sounds good to me if something falls thru with my carsile trip ill just get ya to ship it if thats ok with ya? thanks alot. tony
1969 rs
1966fastback
1969swbc/10
2006gt
1972swb4x4
Old 04-11-2007, 01:34 PM   #19
1969K10
1969K10's Avatar
I've got a disck 8-lug D44 that I can put in. I'm looking for a D60 instead though. Just thought that if you had parts to convert my 6-lug to 8-lug, I'd do that instead of swapping the D44's until I get my D60... THX
Old 04-12-2007, 06:40 PM   #20
msgross
msgross's Avatar
ttt - updated items still for sale
The Garage:
Old 04-15-2007, 08:13 PM   #21
msgross
msgross's Avatar
ttt
last chance for parts before all extra goes to scrap...
The Garage:
