09-06-2002, 01:55 AM | #1 |
MPG...hmm..more like GPM
Caddy Engine Pics
here's the Caddy Motor pics and driveshaft pics you guys wanted to see Please excuse the mess in the pics, it doesn't look that great right now because im redoing the wiring. ok here goes the first one...
(Looking for 67-72 shortwide or shortstep bed) 71 C-10, 500ci of tire shredding Caddy torque, th400, 12 bolt w/Powertrax Lock-Right. Bald Rear Tires 85 Toyota 4x4- 22r 4-banger, 5 speed, I can actually AFFORD to drive this one. |
09-06-2002, 01:58 AM | #2 |
another engine shot(fan is off because im having to space out the pwr steering pump pulley to match the others, because im not using the A/c Compressor)
09-06-2002, 01:59 AM | #3 |
last engine shot-little higher view
09-06-2002, 02:02 AM | #4 |
Drive shaft
heres two pics of the driveshaft-its a custom aluminum drive shaft.
The second pic shows the Caddy Slip Yoke
09-06-2002, 02:04 AM | #5 |
heres the Caddy end
09-06-2002, 02:09 AM | #6 |
tranny crossmember
here's two pics of the crossmember(don't mind the always useful Wal-Mart Plastic bag covering the end of the tranny )
09-06-2002, 02:11 AM | #7 |
2nd one( notice the long snout on the tranny)
09-06-2002, 02:14 AM | #8 |
Last pic
this is where i had to cut for the oil filter
09-06-2002, 03:12 AM | #9 |
its all about the +6 inches
What mounts and towers are you using?
09-06-2002, 07:12 AM | #10 |
That is not the frame you cut for oil filter access is it? Looks like a pretty big hunk. If it is I think you ought to weld it back in and get a remote filter kit. JMO
67 Short Step 250 |
09-06-2002, 08:28 AM | #11 |
Look like a tight squeeze. A lot of effort to be different.
Baby Blue's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=652776 Project 68's Build Thread: http://67-72chevytrucks.com/vboard/s...17#post8442117 www.stonecolumnclassics.com Email: Josh@stonecolumnclassics.com |
09-06-2002, 02:27 PM | #12 |
longhornmail-I had some people at a shop I know custom make the motor mounts( i just noticed i could have bought universal motor mounts from CMD and saved a little money but oh well ) and the tranny crossmember was welded by them too( im not the greatest with a welder, just learning) but I put the motor and tranny in. I figured id let them fab the stuff so it was done right.
umrebelsfan-no its the front crossmember right below the front of the motor( the pic was kinda decieving,I took the picture a little close.) kxmotox247- yes its going to be tight once i get the fenders in there isn't going to be much room under the hood but it'll be worth it. I could always go for the sleeper look and put the badges on the front fenders that say 307 and quiet mufflers,suprise the heck out of wannabe racers thinking its just a crappy old truck
09-07-2002, 08:53 PM | #13 |
I'm a big caddy fan as well. Those engines may not always be quick but they are smoooooth once they get to speed.
I had a 67 convertible. 429 engine was a great one as well. Frank Sinatra stuck in the underdash cassette because God wanted it that way. Huge seating areas and trunk. Got me started on quest to own one of all the GM lines in 67. What a year!
67 Short Step 250 |
