Old 04-08-2007, 05:44 PM   #1
GMCBubba
GMCBubba's Avatar
coil spring boosters
hey guys (and gals), has anyone used coil spring boosters such as these from advance auto parts to help add some height and rigidity back to worn out coils. i'd like to avoid the cost of new coils, but i know i need to do something to regain some stiffness. i've seen some that are metal and some that are rubber/poly. any comments would be great
http://www.partsamerica.com/productd...egoryCode=3197
1969 GMC 3/4 ton, 307, 4-speed NP435GL, DANA 60, 4.10, HD rear leafs, manual everything, leaking oil and water. Now rocking 383, NV4500, power steering, power brakes. Finally undergoing restoration.
GMCBubba is offline   Reply With Quote
Old 04-08-2007, 05:46 PM   #2
dave2953
Dave's not here, man
dave2953's Avatar
Re: coil spring boosters
Does the weight of the truck keep them intact? It's hard to tell from the pic how they stay put.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 04-08-2007, 06:12 PM   #3
GMCBubba
GMCBubba's Avatar
as far as i can tell, you kind of wedge them inbetween the coils. the metal ones screw in. the rubber versions wedge in when the spring is unsprung.
Old 04-08-2007, 11:48 PM   #4
KFreddy
Active Member
KFreddy's Avatar
This is a great and inexpensive product http://www.airliftcompany.com/ I used the airlift1000 set up in my '96 Impala SS it was fantastic.
Good luck,
-Fred
KFreddy is offline   Reply With Quote
Old 04-09-2007, 12:34 AM   #5
wibilly
wibilly's Avatar
my new driver [69 lwb] c/10 has them in the front it sits higher in front than my 69 c/20 i'm thinking i'll take them out and see what happens. of course i want it lower
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 04-09-2007, 12:49 AM   #6
RACINJASON22
GEARHEAD
RACINJASON22's Avatar
IMO they are kind of a bandaid for a spring going south. I have seen them used though and they do work as described.
72 SWB 2WD MY PROJECT
72 LWB 4X4 FUTURE PROJECT
SUBSCRIBE HEREBOARD VENDORS HERE
NORWOOD MEET SURVIVOR!
RACINJASON22 is offline   Reply With Quote
