1987 Chevy suburban not charging problem
![]() Added: Someone thinks i have the wrong alternator on the truck, and that a one wire alternator should be on it. There is a connector next to the alternator that isnt connected to anything. I dont know what its for. right now the alternator has the black connector connected in the back then the wire to the pos. battery and a fusible wire to the junct. box. I dont know what the connector is thats coming out of the harness and not hook up to anything. Last edited by KennyB49221; 04-08-2007 at 11:20 PM. |
Re: 1987 Chevy suburban not charging problem
The alternators I've dealt with on my 82, 84, and 85 Suburban have 3 connection points. There is a post on the back of the alternator and 2 spade terminals on the side....the side connection has a plug with 2 wires going to it. The terminals on the side are part of the internal voltage regulator and tell the alternator when to charge. I'm not sure when GM went to the one wire alternators, but I would think they would keep the 87 the same as the others up til the body style change in 91. If there is a NAPA close by take your alternator there and see if it is the right one. Also, buy a Haynes manual. It has a lot of good info and with it you should be able to trace out your wiring.
I'm not sure on this, but I think you can buy a new harness for just the engine compartment...LMC may have it. When I completely rewired my 71 chevy truck I bought a painless harness for something like $350 thru JC whitney...not sure of the price for the newer Suburban. Can you take pics of what you are working with? After reading your post again, I think that connector on the harness needs to be plugged in to the alternator....look for a space on the side that has two spade terminals. Hope this helps.
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 Last edited by rcbildr; 04-09-2007 at 03:24 AM. |
500 for a painless wiring harness for newer burb
Update....... I bought a new self exciting one wire alternator (I think its a delco 12 Si) and now the truck is charging, Thank God. Its giving out about 14.7 volts with the headlights on so I think thats fine. Thanks everyone for the help.
