Old 04-08-2007, 10:34 PM   #1
HugrOrang71
Bite me, import boy
HugrOrang71's Avatar
65 C-10 Underhood wiring- bulkhead plugs
I have 2 plugs coming from the firewall, one is located near the LH inner fender and the other is just just above the RH valve cover. I'm thinking that the LH one feeds the front lighting and the one above the valve cover is the gauge feed, coil power and crank signal to the starter. Correct?
Should there be a wire to a junction block to supply power to the ignition and dash (like on the 67-72 trucks)? Someone had added a large gauge wire from the fuse block through an extra hole in the firewall. I'm not sure if this is what was being used or not?
Any source for a decent wiring diagram?
Thanks,
Jason
Jason
'71 C-10 Deluxe-under construction '69 C20, 396,T400-donor truck, '65 C10 project
"Facts are meaningless, You can use facts to prove anything that's even remotely true."
HugrOrang71 is offline   Reply With Quote
Old 04-08-2007, 10:58 PM   #2
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: 65 C-10 Underhood wiring- bulkhead plugs
The center one feeds the ignition, solenoid, oil and temp senders....while the side bulkhead feeds the headlights, horn, and has the battery feed from the horn relay to the rest of the harness
John
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 04-09-2007, 08:47 AM   #3
rodnok1
rodnok1's Avatar
Here a linky to color wiring diagram I did last year
http://67-72chevytrucks.com/vboard/s...d.php?t=193429
64 Panel Rebuild Pics
Clutch Replacement and Borg Warner T10 Trans Rebuild
64 Panel 1/2 Ton
350cubes/400hp
BorgWarner t-10
3:73 Auburn Posi
rodnok1 is offline   Reply With Quote
Old 04-09-2007, 12:39 PM   #4
HugrOrang71
Bite me, import boy
Thank you both for the info. It will help quite a bit.
Jason
Jason
