Old 04-08-2007, 10:51 PM   #1
corkscrew
How does power get to the brake light switch?
i was tracing my wires and it went all the way down under the floor mat..anyone know where these wires go?
corkscrew is offline   Reply With Quote
Old 04-08-2007, 11:11 PM   #2
centsless
sufficiently talented fool
centsless's Avatar
Re: How does power get to the brake light switch?
Power comes from the fusebox to the brakelight switch. It then goes from the switch to the turn signal switch. Then it goes out the firewall near the gas pedal and down to the frame.
"it's impossible to be surrounded by idiots when you are part of the circle"
2003 Suburban
2002 Pontiac Montana
1981 Corvette
1966 Impala Convertible
Click here to support the board
centsless is offline   Reply With Quote
Old 04-08-2007, 11:14 PM   #3
corkscrew
cuz yeah i hooked up the switch but there was no power coming to those wires, other circuits were working so im not sure where the power is not connected
Old 04-09-2007, 12:38 AM   #4
corkscrew
anybody know why this circuit would not draw power when the rest do? possible problem locations??
Old 04-09-2007, 05:04 AM   #5
JimKshortstep4x4
Is the fuse good?
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 04-10-2007, 06:21 PM   #6
corkscrew
there is no fuse
Old 04-10-2007, 09:01 PM   #7
corkscrew
anybody with a diagram?? this would be great also is the turn signal switch the signal switch on the column??
Old 04-10-2007, 09:34 PM   #8
centsless
centsless's Avatar
There is a brake light fuse. If you have no power to the switch, you need to check the fuse first.
2003 Suburban
1981 Corvette
Old 04-10-2007, 09:57 PM   #9
corkscrew
i bought a whole new painless performance wiring kit, not the stock wiring and fuse box...
Old 04-10-2007, 10:05 PM   #10
68 P.O.S.
I have a Painless harness as well and I didn't have that problem. I would check the fuses as stated above. I'm assuming you tested the wires to be sure if there is power or not. Are you sure your brake switch is good?
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 04-11-2007, 12:54 AM   #11
corkscrew
brake switch is brand new....the wires that lead to the brake switch have no power to them...in my fuse box there is no fuse labelled break switch, anything else it could be under?
Old 04-11-2007, 10:41 AM   #12
hootlube
Do the turn signals work? (Probably not). If memory serves, power comes from fuse box, to column, through turn signals and hazard, to brake switch, to brake lights.
hootlube is offline   Reply With Quote
Old 04-12-2007, 01:11 AM   #13
corkscrew
signal lights work...
Old 04-12-2007, 11:04 AM   #14
Imacarguytoo
Call painless wiring. They helped me over the phone every time i needed it.
'67 C20 Lwb 350 4-Speed
'01 Chrysler Concorde LXI (wifes ride)
'91 Gmc Suburban 3/4 2wd 454 Tbi
'51 Jeep Cj3a "Willys" 350 V8
Imacarguytoo is offline   Reply With Quote
Old 04-12-2007, 11:57 AM   #15
kwmech
The wires that go under the floor mat go to the fuel sending unit and the dome lamp.
Old 04-12-2007, 08:17 PM   #16
68 P.O.S.
I just checked my fuse box. The brake fuse on mine is labeled as "Stop", so yours should be the same. I would assume Painless labels everything the same, but sometimes you never w/ some companies.
