Old 04-09-2007, 12:55 AM   #1
cameeks
Long Fleet Club
cameeks's Avatar
5 lug axles?
Where is a good place to find some 5 x 5 lug axtles for my '69? I'm wanting to just replace them and keep everything else in my rear end the same.
Chris Meeks
'69 Chevy Custom/10 Long Bed <-- Thread of the work I did before selling.
Truck is now finished to the new owners design and running around.
I was shown some pictures of the finished product. At least it survived the junk yard.
FAQ Index by Krue Site Vendors Subscribe Here Forum Rules
cameeks is offline   Reply With Quote
Old 04-09-2007, 01:13 AM   #2
basketcase
basketcase's Avatar
Re: 5 lug axtles?
Chevy 5 lug axles are longer than the 6 lugs. Aftermarket ones are now available from several sources but I'd bet they are all made by Moser.
You can go there or to CPP or ECE.
Tom
'69 swb stepside in progress.
'59 Corvette lifetime project
basketcase is offline   Reply With Quote
Old 04-10-2007, 01:22 AM   #3
Aarons72s
Re: 5 lug axles?
Get 5 lug axles out of a 73-81 12bolt 1/2 ton 2wd chevy or gmc pick up. Then grab a set of 74-87 2-3/4" x 11-5/32" brake drums to make up the difference in the widths. Then just remove your old axles and drums and install the new ones. Good luck.
Aarons72s is offline   Reply With Quote
Old 04-10-2007, 08:33 AM   #4
noahdallas
noahdallas's Avatar
Re: 5 lug axles?
Could you please tell me where you would get the "set of 74-87 2-3/4" x 11-5/32" brake drums" to make up the difference? thanks....
noahdallas is offline   Reply With Quote
Old 04-10-2007, 11:19 AM   #5
cameeks
Long Fleet Club
cameeks's Avatar
Re: 5 lug axles?
I am doing the 4 disk conversion so the drums wont help. but it looks like good info for noahdallas
Chris Meeks
Old 04-10-2007, 04:46 PM   #6
zacut
67 chevy SWB Fleetside
Re: 5 lug axles?
disks should make it even easier to use the 73-87 axles. just space out the caliper correctly to the new disk.
67 Chevy C10 Short Wide
350/350 ... Front Discs ... ECE Lowered 2.5/4
Vintage Air ... Oak Bed Floor ... Painless Wiring
Brothers 1 pc Windows ... Lokar Pedals, Shifter, E-brake
Ididit Column ... VDO guages
zacut is offline   Reply With Quote
Old 04-10-2007, 06:43 PM   #7
low70chevy
Re: 5 lug axles?
i purchased a set of yukon five lugs from randy's ring and pinion
low70chevy is offline   Reply With Quote
Old 04-11-2007, 09:35 AM   #8
BowTieOgre
Re: 5 lug axles?
Due to the lack of availability in my area I ordered a set of axles from a guy on Ebay for $85 shipped. Heirgears was the name IIRC. I could have spend 3 times as much on new ones but these were in good condition and came with c-clips and wheel studs.
1986 C10 - LWB, 305/700r4, posi, vortec heads
BowTieOgre is offline   Reply With Quote
Old 04-11-2007, 04:43 PM   #9
noahdallas
noahdallas's Avatar
Re: 5 lug axles?
I picked up a '69 6 lug rear end with trailings so I can replace the "homemade" leaf spring setup I have...... Question is where can I get the 5 on 5 axels?? Any where near me in the DFW area or do I need to order some new ones from jeg/summit? thanks....
Old 04-12-2007, 11:45 AM   #10
cameeks
Long Fleet Club
cameeks's Avatar
Re: 5 lug axles?
Robznob11 pmed me about Randys Ring and Pinion. He said that is where he got his from and spent $310 shipping included. He also said they were Moser axles. I'm going with them.
Chris Meeks
