![]() Join Date: Aug 2005
Chroming over Metalwork???
I've been wondering about this for a while and figure someone on here should be able to shed some light...
I've made some modifications to a bumper and I want to re-chome it. The question is: Obviously you can't chrome over plastc body filler so; Is my only option to make the metalwork perfect, or can I use lead-filler/body-solder and chrome over that? ...any other options? ![]() |
![]() ![]() Join Date: Jul 2002
Re: Chroming over Metalwork???
It has been a while, but yes you should use a metal based filler, weld if you can is the best. You don't chrome directly to the steel. The process adds 1 or 2 other metals coatings (thats the part I forget, how many and what exactly they are), then the chrome platting adheres to them. Chromes does not actually adhere to steel.
They usually fill in imperfections w/weld or lead (solder), then copper, & then block-sand the finish just like you would bodywork. The process sometimes takes several applications to get the surface perfect.
Parts and more parts
I agree with what Scoti says.....It takes a lot of time, but I have seen some bumpers modified to fit trucks that came from other vehicles and once completed, you would not know that they had been spliced.
Happy to be here
![]() Join Date: Mar 2000
Your best bet is to talk to the plater that you plan to use. While the plating process is somewhat standard, all platers have a tendency to create their own plating formula. Sometimes this requires using different materials at different times in the process.
Guess that means I'll have to pick out a plating shop before I finish the bumper
before starting i'd suggest going to the plater tell him what you intend to do then follow his instructions// you might also ask for a ballpark price of how many hundreds of dollars it will cost(probally closer to a thousand than a hundred
A thousand to get a bumper chromed?
Price of metals have gone up, Chrome is a metal.
chrome aint cheap!! a perfect bumper that just needs to be stripped dipped and polished will start at $500-$600 and additional filling finishing or prep work will make the meter spin// you probally cant get a door handle chromed for a hundred bucks
So how do the new chrome ones sell for $150?
chinamen work cheap
#13 |
#14 |
I am a Referee of life.
The other factor in cost is the EPA.Here in the U.S. we have big brother watching out for the enviroment.In China they just dump the waste in the lake.Some of the chemicals used in plating are deadly.Arsnic is one of them.I work in a commercial laundry and we have to monitor our wastewater to be sure we don't contaminate the enviroment.One of the things we monitor is arsnic because of the plating companies we supply uniforms to.There are actually some pollutants that are required to be the responsibility of the initial producer.They are responsible for these things"Cradle to grave"
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
#15 |
The chrome guy I use wont touch something that's modified unless he is the one who did it. Make sure yours will. He can't guarantee the work under the chrome and he dosen't want shoddy work with his name on it.
