04-09-2007, 01:04 PM | #1 |
Power steering junk run
I'm going to look for the parts to complete my ps. I've got a 68 box and a later model 305 (mid 80s I'm assuming, haven't checked the numbers) in the truck. What should I look for in the area of pump, brackets, and lines. Thanks.
BRENT -'68 Stepside Project -'98 Z71 Daily Driver -Enough extra parts to build another truck and a half |
04-09-2007, 02:09 PM | #2 |
Son of a gun
Re: Power steering junk run
Get everything from a 73-87 truck. You will like the variable PS box!. That last bolt on the bracket in the motor mount is a PAIN to get to!
Bill BEATERS ARE NEATER |
04-09-2007, 03:34 PM | #3 |
I was planning on using the box that I have. Can I use it and everything else from a 73-87? What are the advantages of going with the 73-87 box? I know I've heard that '76 has a quicker ratio. Anything else?
04-09-2007, 04:12 PM | #4 |
Son of a gun
You can use everything else 73- 87 (or 68-87 for that matter). The 76-87 box is variable ratio, like 3 1/8 turns to lock. It gives a much more "modern feel" to your steering. I know with my old 69 box it felt kinda like cranking a bus steering wheel around in a parking lot, I think it must be 56 turns to lock .
