Old 04-09-2007, 01:08 PM   #1
76bonanza
76bonanza's Avatar
vacuum guage install
I am installing a vacuum guage and have to splice into one of my vacuum hoses, was thinking of putting a tee conector in the hose that goes to the tranny? I think it would be the best place.
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 04-09-2007, 01:17 PM   #2
Re: vacuum guage install
Mine have always been teed off the distributor connection, but not sure what the difference is. I have not used one in a long time except for tuneups.
Old 04-09-2007, 01:17 PM   #3
ktlx1
I recently did this as well, I connected a t-fitting into the vacuum line that runs from the distributor to the carburator. Works great in my application, using an auto meter vacuum gauge
ktlx1 is offline   Reply With Quote
Old 04-09-2007, 01:20 PM   #4
Blue85
Oilfield Trash
Blue85's Avatar
Anyone know where the factory gauge was hooked up to?
14 Dodge 3500 Mega Cab
08 Dodge 3500 Mega Cab
87 Chev 3+3 4x4
80 GMC K10 High Sierra bone stock
70 Chevelle 350SS long term project
68 GMC 3ton Grain Truck/Garbage wagon
50 Pontiac 2 Door Coupe Project
"I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr.
Blue85 is offline   Reply With Quote
Old 04-09-2007, 01:59 PM   #5
76bonanza
76bonanza's Avatar
I assume you guys are running your advance on the full vacuum port on carb and not the ported one otherwise you would get no reading at idle.
1968 c10
lowered 3" 4"
Old 04-09-2007, 05:23 PM   #6
ktlx1
Yes, you will know you have the correct vacuum by pulling off the hose to the distributor leading to the carb, motor will run sluggish.
Old 04-09-2007, 05:36 PM   #7
bryanw1968
bryanw1968's Avatar
Vacuum advance shouldn't be on the port with vacuum all the time?
bryanw1968 is offline   Reply With Quote
Old 04-09-2007, 06:50 PM   #8
76bonanza
76bonanza's Avatar
Well that is debatable, I for one love it on full vacuum, some will disagree many will not.
1968 c10
lowered 3" 4"
Old 04-09-2007, 06:55 PM   #9
Billla
Billla's Avatar
Generally, a completely stock engine is fine with ported vacuum. If it's been warmed over at all, the slight vacuum advance at idle from the non-ported (manifold) vacuum will improve the idle quality and off-idle response.
Billla is offline   Reply With Quote
Old 04-09-2007, 06:56 PM   #10
bryanw1968
bryanw1968's Avatar
But typically you don't want vacuum at idle pulling advance into your initial right? Once you crack the primaries you expose the other vacuum port and that is the one that's supposed to go to the dist.
Old 04-09-2007, 07:20 PM   #11
Billla
Billla's Avatar
Yes, you do Uprated engines typically see much smoother idle with some advance at idle. This is pretty broadly accepted practice, although someone may have different experience.
The "supposed to's" pretty much go out the window once you start re-engineering (i.e. adding horsepower to) the design.
Old 04-09-2007, 07:50 PM   #12
sjarrett71
sjarrett71's Avatar
What's the benefit of using a vacuum gauge?
-Scott-
sjarrett71 is offline   Reply With Quote
Old 04-09-2007, 07:56 PM   #13
Billla
Billla's Avatar
It fills that blank spot in the gauge package
Old 04-09-2007, 10:11 PM   #14
You can educate your foot for better gas mileage for one!
Old 04-09-2007, 10:50 PM   #15
bryanw1968
bryanw1968's Avatar
HA!
You're right!!! It's fun to watch the gauge change!
Seriously it helped me tune when I was having air/fuel problems.
It's nice to have the gauge inside to see where your vacuum is when the weather changes and affects your idle.
And, yes it does fill that empty gauge hole
Old 04-09-2007, 11:10 PM   #16
centsless
sufficiently talented fool
centsless's Avatar
Cuz it's COOL!!!!!!!!!!!!!!!!!!!!!!
and it fills the empty hole...
"it's impossible to be surrounded by idiots when you are part of the circle"
2003 Suburban
2002 Pontiac Montana
1981 Corvette
1966 Impala Convertible
Click here to support the board
centsless is offline   Reply With Quote
Old 04-09-2007, 11:26 PM   #17
76bonanza
76bonanza's Avatar
And if you have a vacuum leak it makes it easier to spot (plus the needle dances when the motor goes vrooom)
1968 c10
lowered 3" 4"
Old 04-10-2007, 12:36 AM   #18
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Here's a good read on vacuum if you're interested.
http://www.lbfun.com/Corvette/Tech/v..._explained.pdf
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 04-10-2007, 01:15 AM   #19
WinDancer
The Original HotRod KnifeMaker
WinDancer's Avatar
I doubt anyone but another owner will ever notice that the one gauge hole doesn't have anything behind it- but I am doing mine, too, to fill the hole I know is there
Dave
69 GMC SWB 2WD 454 Turbo 400
WinDancer is offline   Reply With Quote
Old 04-10-2007, 01:45 AM   #20
Bob B.
The vacuum gauge was only 'stock' on the larger (C-50 and 60) trucks with vacuum brakes. The gauge read vacuum in the vacuum tank under the cab. I think the best place to hook it to is manifold vacuum.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 06-12-2007, 09:51 PM   #21
WinDancer
WinDancer's Avatar
So what else did you have to do to get the vaccum gauge installed and working?
Dave
Old 06-12-2007, 11:26 PM   #22
Bob Moore
I believe the "stock" hook-up was made to the fitting in the intake manifold behind the carb. Not to the carb at all but to the manifold. The fitting also serves the brake booster and transmission(IIRC)
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 06-13-2007, 08:01 AM   #23
'68OrangeSunshine
'68OrangeSunshine's Avatar
My vacuum gauge is run to a small tap in the intake manifold with 1/8" copper line. Cleaner signal and you don't have to disconnect it every time you pull the carb.
Old 06-13-2007, 09:10 AM   #24
kwmech
Last year I found a dash with a pressure guage in the hole. I still have it packed in a box somewhere.
