Old 04-09-2007, 01:56 PM   #1
kxnomore
kxnomore's Avatar
What's the story with the AC diverter box
Does anyone know if this part is discontinued? Everyone I've talked with says it's on backorder... If it is no longer available, has anyone ever repaired one? My lever mechanism is twisted and the box is cracked.
Thanks in advance.
kxnomore is offline   Reply With Quote
Old 04-09-2007, 04:37 PM   #2
clay68c10
clay68c10's Avatar
Re: What's the story with the AC diverter box
I got one from GMC Pauls about a year ago. Have you checked with the board vendors?
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 04-09-2007, 06:20 PM   #3
kxnomore
kxnomore's Avatar
You may have got one of the last ones. I looked through all the classifieds, and didn't find any. I heard they came from GM, but now have not been available since November.
Does anyone know if this part is specific to AC trucks?
Old 04-09-2007, 06:35 PM   #4
Bob B.
It is specific to trucks with A/C. The story I got is that G.M. is sold out of them, but is supposed to have more in a month or so. I'll bet if G.M. does discontinue them, the aftermarket will make a re-pop.. They break all the time.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 04-09-2007, 07:58 PM   #5
kxnomore
kxnomore's Avatar
Thanks Bob B.
I'll keep my hopes up as it's getting warm out and I can't completely shut off the heater without that box.
Old 04-09-2007, 09:00 PM   #6
webbes
Wes had them a month ago. You might try him.
webbes is offline   Reply With Quote
Old 04-09-2007, 10:06 PM   #7
Steven B
Steven B's Avatar
Yes, check with Wes at ClassicHeartbeat. I think he still has a couple.
70 Jimmy 4x4
71 GMC 2500
Too bad stupidity isn't painful
Steven B is offline   Reply With Quote
Old 04-09-2007, 10:10 PM   #8
sjarrett71
sjarrett71's Avatar
There's one on evilbay right now. It's supposed to be NOS. THe item number is 150110728260.
If anyone can post the link, please do. I'm not that technologically advanced.
-Scott-
sjarrett71 is offline   Reply With Quote
Old 04-09-2007, 10:15 PM   #9
Sammy
I recently bought an A/C delete cover on ebay although not cheap sure cleans up the firewall & keeps your heater working.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 04-09-2007, 10:24 PM   #10
haokah
haokah's Avatar
When my door broke summer before last, I found one in stock at Grumpy's
http://www.grumpystruckparts.com/item340575.ctlg
I like pigs. Dogs look up to us. Cats look down on us. Pigs treat us as equals.
-Sir Winston Churchill
haokah is offline   Reply With Quote
Old 04-10-2007, 09:38 AM   #11
Huck
Huck's Avatar
I bought an aftermarket one where the rubber fell apart within 2 years. Sometimes you can find one in a slavage yard that is still good. Then tended to wrap and then the door would brake loose from the shaft.
Huck is offline   Reply With Quote
Old 04-10-2007, 02:21 PM   #12
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
They are all "JUNK"-by design! I also am pretty sure GM was the sole source for all of them. I put a new one in my Blazer and it was broken again within 6 months (in Washington???).
I have never seen a good used one. The plastic flapper door breaks away from the shaft, UNDER the rubber seal, so you usually can't see it. You have to physically check it...and as you said, they warp from heat.
You can strengthen/repair these, if the housing is straight. You need to make tabs that you can drill & pop rivet to the flapper door and then tack weld to the metal shaft. Take it slow, keep it cool (water) and keep the welds small.
PICKMUP is offline   Reply With Quote
Old 04-10-2007, 04:12 PM   #13
kxnomore
kxnomore's Avatar
Thanks everybody for your help! I did call Wes at Classic Heartbeat and he is looking for one for me now.
The story is that GM stopped making them, but may start up production again, no one is sure yet.
I'm going to try to pick one up now before only used ones are left! Anyone have any tips on keeping them working well? I like the rivet and weld idea. Maybe add some reinforcing braces here and there?
