Old 04-09-2007, 03:36 PM   #1
snacob14
Can I use this for parts
my neighbor has a 93 chevy conversion van. I was wondering if the front crossmember would bolt to my 68 chevy frame. also, can I use the 700r4 out of it or not. It is computer shifted I believe, but i don't know. I was thinking of at least using the front crossmember and all accessories including the rearend if it will fit to at least get myself some power brakes
snacob14 is offline   Reply With Quote
Old 04-09-2007, 04:04 PM   #2
brak
brak's Avatar
Re: Can I use this for parts
don't know about the crossmember, but yes you can use the tranny.
TCI makes a kit that converts it to vacuum controlled lockup, plus it allows you to add a switch to turn off lockup allowing you to tow in 4th gear like the new trucks (my favorite feature).
The kit costs about $75 and is very easy to install.
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 04-09-2007, 04:48 PM   #3
724x4a/cchevy
Self-proclaimed LED man
724x4a/cchevy's Avatar
snacob14, Sent you a PM
Justin
My LED Website
My Photobucket Album of LED's
Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK
I also do LED:
-Third Brake/Cargo
-Brake (truck and burb)
-Reverse (truck and burb)
-67-68 Front Turn Signals
-69-70 Front Turn Signals
-71-72 Front Turn Signals
-GMC Front Turn Signals
I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once
Norwood Survivor
724x4a/cchevy is offline   Reply With Quote
Old 04-09-2007, 05:23 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
actually, I think by 93, the 700R4 was dead, and the totally computer controlled 4l60E was in place. If that's the case, installing that would cost WAY more than it is worth.
IIRC, the van front end is too narrow for a truck.
Old 04-09-2007, 05:38 PM   #5
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
I agree with Longhorn, I thought a 93 should have a 4l60E
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 04-09-2007, 09:17 PM   #6
snacob14
so i need to find out if it is a 4l60e
Old 04-09-2007, 10:36 PM   #7
bad72c10
bad72c10's Avatar
The 700r4 was called a 700r4 from 82-92. In 93 they called it a 4L60, but the E didn't come until 94. So it may be called just a 4L60, but I don't think it'll be a 4L60E. I think they changed to electronic in 1994, because I have a 94 S-10 with a 4L60E. That's kind of confusing, but I think its the truth. Justin
'72 C/10 SWB 355/ broken TH350 and 3.07s Soon to be 355/700r4 and 3.73s
bad72c10 is offline   Reply With Quote
