09-06-2002, 11:50 AM | #1 |
is a two bolt main worth beefin up?
my old engine is on a stand in the backyard and i wanna rebuild it for my dads 71 blazer just in case the motor in it takes a crap. problem is its a two bolt main, is it safe to bore out, and throw in some performance parts (intake, cam, etc.)? or should i just rebuild it stock and have it as a back up motor sittin around?
Current owner of 2016 2500 Silverado Midnight Edition. Former owner of: 69 1/2 ton, change from long/fleet to short/fleet, shaved door handles, shaved tailgate, 4/6 drop, power windows, 700r4 72 blazer, 350 with Holley Commander 950 DFI, crane energizer cam, 350 tranny, dual sanderson blockhuggers/magnaflow exhaust |
09-06-2002, 12:20 PM | #2 |
WTF
Two bolt mains have no problem to the stanard bolt on tricks. They can handle towards 500 or so hp, if you were going to shoot gobs of nitrous or put a blower on it that would be different. But just normal street stuff it will be fine and I think Milodon sells a kit to convert 2 bolts to 4 if you are still worried. Hope this helps some.
Some people are wise, some people are otherwise. 72 cheyenne primer factory air lowered rallyes with flat caps flowmasters 12 bolt 3.73 350/350 combo needs rockers . Cowl hood installed. 81 Malibu wagon lowered with 17's bright ass yellow and v-6. 71 225 Electra all original 455/4 81 z28 |
09-06-2002, 02:47 PM | #3 |
urban fourwheelin
I've been told by a few engine builders that a two bolt block that is converted to four bolt is stronger than a stock four bolt block. I think it's because the two new bolts on the caps are installed at an angle instead of straight up and down like the original.
09-06-2002, 03:10 PM | #4 |
I WOULDN'T WORRY ABOUT A 2 BOLT BLOCK NOT BEING STRONG ENOUGH. I'VE BUILT ALOT OF (OVER A DOZEN) 2 BOLT BLOCKS UP TO 450 HP (REAL DYNO, NOT AN ESTIMATE OR A DESK TOP DYNO) & HAVE NEVER HAD ONE FAIL FROM BEING TOO WEEK ON THE BOTTOM END. OF COARSE I PREFER A 4 BOLT, & USE THEM ALOT BECAUSE THEY ARE PLENTIFUL, & COST ABOUT THE SAME FOR CORES. IF IN DOUBT, PICK UP A CORE FROM A BONEYARD FOR $50 - $75.
(MILODINE AFTERMARKET CAPS ARE ABOUT $210 & REQUIRE ABOUT ANOTHER $150 - $200 IN DRILLING,TAPPING & ALIGHN BORING & HONING)
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST Last edited by junkyardjohn; 09-06-2002 at 03:17 PM. |
09-06-2002, 03:14 PM | #5 |
its all about the +6 inches
Somethign that is forgotten, is it is RPM that rips an engine apart..not H.P. (coincidently, it takes RPM to make H.P. though)
You can spin one to 5500 on a reg basis, ans even to 6500 once in a while. I have no reason to believe my 350 is a 4 bolt, and she's seen 7000 a couple times, and 6500 more than I can count. The splayed conversion caps are much stronger (if done right) then a stock 4 bolt. |
09-06-2002, 03:27 PM | #6 |
So Many Ideas, So Little Money
2bolts are fine, for race motors guys want the 2 bolts and put billet splayed caps on, there i more meterail in a 2bolt compared to a 4 bolt.
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors 71 C10 with 454 99 S-10 5.1L SBC 700R4 09 Malibu Marshalltown, Iowa |
09-06-2002, 04:19 PM | #7 |
Four bolt main blocks are desirable in high performance applications because the extra strength of the additional bolts keeps the bottom end rigid and less prone to failure. However, a properly prepared 2 bolt main engine will work just fine (often times you'll lose a rod bolt before you break a crank because it's "only" a 2 bolt main. Compliments of NastyZ28.com.
Brandon. |
09-06-2002, 04:20 PM | #8 |
now...for a 400, it is bass ackwaerds, and you WANT a 2 bolt. The 4 bolt is not as strong as the 2 bolt...but this is only on the 400 small block.
09-06-2002, 07:03 PM | #9 | |
Bloo
like longhonrmail said, in 400 SBCs, the outside two bolts on the block are to close to the edge, and make it more likely to crack.. ive got a 2 bolt 355 in my 4x4, and will have a 2 bolt 400 in the 2wd.. my 355 isnt anythign special really, but decent little motor.. 350 bored 30, flat tops, 487s heads, Weiand 8004 intake, Holley 4175 650 CFM carb, hei, headers.. dont really know the real numbers but its estimated at 330 HP/370 torque.. so in short, i think your 2 bolt will be fine
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
09-06-2002, 08:58 PM | #10 |
install main studs(arp) and have lined honed...good rods and bolts and your good to go....
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
09-07-2002, 04:10 AM | #11 |
ok well now i know not to worry about my 350 2 bolt. matter of fact i think i might just convert to 4 bolt since you guys are saying that its stronger than 4 bolt stock. any answers on how much the Milodon conversion kit is?
well what ever engine that ends up in it, it will be driven a couple times a week, but the real action will be in the Pismo dunes on the Cali coast. well give it a little lift, probly a 700r4 between this engine and the 3.73 rear, and a darn clean restoration. any reccomendations on how to get most out of it (cam, rocker, intake, etc. -wise)? by the way- my engine in my 69 tops out at about 5050 rpms. brand new crate with the additions listed below, why cant i hit 6-7K rpms? (obviously, im new to all this engine building crap)
09-07-2002, 10:58 AM | #12 |
whats limiting your rpm 's.....cam...heads....intake... those are the big three. your engine has to be able to breathe at hi-rpms. thats when the flow numbers from your heads come in handy. the cam manufactors put a usable rpm range on the cam, so you can see what rpm range your in...but you must have all three set up for the rpm range you want
09-08-2002, 10:32 AM | #13 |
well ive got a darn tall intake. very comparable to the edelbrock airgap, but accel makes it. then a spacer, then the throttole, then another spacer, then the K&N. my cam float is 6500. but i do have stock heads.
so a reccommenation might be to throw some roller rockers on?
