Old 04-09-2007, 07:26 PM   #1
Towstrap
Towstrap's Avatar
whats the SPECs of your truck
well heres mine is "Blue" it started its life as a 70 chevy C30 1ton flat bed 2wheeldrive went with a 86 chevy 3/4ton frame with a 8 lift in the front an a stack of two 3/4ton leafs with shackle flip in the back, got my axles off of an 78 dodge snow commando 3/4ton Dana6o open diff and a chevy 14 bolt thats welded with rear with disc brakes,it has 4:10 gears, rolling on 44s TSL in the front and Boggers in the rear,6AL MSD, HAD a built 350 small block, 350 trans with a 203/205 doubler transfer case with a triple stick , crossover steering, custom bumpers and i can not forget about my Co-poilt "Ducky" and now im working on a new project only a hand full of people knows about soooo
Upgrade: body swap to a 68 suburban, military 2 1/2 Rockwell axle, Bigg Block, and 56 tractor tires
Towstrap is offline   Reply With Quote
Old 04-10-2007, 08:12 AM   #2
vtblazer
vtblazer's Avatar
Re: whats the SPECs of your truck
Nice build, Towstrap.
My 71 one ton Blazer specs: Front to rear.
*3/8" steel front bumber holding in the Warn 9.5K winch
*69/70 grill cause it looks alot better than the tube one that was on it
*Tranny, steering and engine oil coolers
*4 core rad with modified cowl and two speed electric fan
*TBI'd 383 stroker motor w/serp belt set up
*2.5" center dump vette rams horn manifolds with x-over and FlowMaster mufflers
*Factory tilt column with newer GM leather wrap wheel
*High pinion Dana 60 from a 79 furd w/5:13's
*Cross over steering
*4130 axles with spool and beefier u-joints
*PSC ram assist steering
*One ton front shaft from High Angle with a 12" slip
*Built th-400, extra clutch, bigger spragg count, blah-blah but built tough
*203/205 doubler with triple sticks and skid plate
*High Angle double cardon shaft out back
*14b FF with disc's, Detroit locker and 5:13's from a 98 Chevy
*6" Alcan springs with shackle flip that puts it to about an 8" lift
*40" TSL's with Staun internal bead locks on steel 16.5x9.75 wheels
*Full family cage
*Corbeau seats with 4-piont harness
*Rock sliders in place of rocker panels
*Fuel cell with internal pump in factory location that only hangs 3.5" below the frame intead of the original 7.5"s
*Flush mount fuel door to replace the tree catcher
*Hard top and soft tops
*3/8" steel basically square back bumper
So that's the basics.
vtblazer is offline   Reply With Quote
Old 04-10-2007, 10:21 AM   #3
Towstrap
Towstrap's Avatar
vtblazer Nice
any others
Old 04-10-2007, 11:15 AM   #4
CrashEd
72 chevy
CrashEd's Avatar
Both of you guys trucks sound really nice.
I have a 86 blazer with a 383 and 40 groundhawgs on it. A small lift with the fenders almost cut of front and rear its easy to get in for me though.
Its preaty much stock with the 10 bolt rearend welded.
It gets me around good.
My 72 k10 LWB is going to be a little bigger with 3/4 ton drive line and i hope soon to have 39.5/16 boggers on it.
Ed
CrashEd is offline   Reply With Quote
Old 04-10-2007, 11:22 AM   #5
1969K10
1969K10's Avatar
Well, mines a work in progess.
It's titled as a '69, but has '68 cab & dog house on it.
"Stock" were still applicable, read sig...
307 V8 replaced with 350.
D44 in front - looking for D60 - will be locker.
12 bolt in back - 14bolt getting closer to going in - will be det. locker, I think.
Want a winch, and I think it'll be the truck I'm after...
Nice rides guys - I don't do near the thrashing that y'all do, just a good work/play truck.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 04-10-2007, 12:33 PM   #6
Burt4x4
Burt4x4's Avatar
Ok I'll play..avoiding my work hehehe
1972 K5 new to me in 1993
454 = board 30over, inlarged valves in 781heads,Comp cam,Mallory ignition,EdelBrock Pro-Flow MPFI, balanced, decked & shaved. ORD engine mounts & crossmember, dual Felx-A-lite elc. fans. Dyno tuned giving me 286Hp & 390Tq AT the rear tires, baiscally alot of fun to drive
Thorley Headers w/2.5"pipe and 50seires Flowmasters & a H pipe
Dual Optima Batts w/Hellroaring iso/combiner
Mico Lever-Lock (line lock for the front brakes)
Sm465 w/Luk ProGold clutch assy. & hydrolic swap out the manual linkage
Np205 stock except for the poly mounts
Front = D60 (currently being installed) Lock Rite, 4:56 Yukons(the rest is stock for now) DIY4X Razorback cover
WFO Crossover/Highsteer setup, heavy duty version (rods,arms,TREs, etc..)( currently being installed)
PSC Hydro assist kit (gearbox, pump, 8"ram)(currently being installed)
4" spring lift
Rear = 14FF w/disk brakes Detroit locker & 4:56 Yukons(currently being installed)
5.5" spring lift
H1 8 bolt recentered double beadlock wheels w/PVC inserts
36-13.50/16.5 Irok biasply Swampers
37gal NWMP tank
Homebrew skidplate
6pt roll cage
1/4" steel bumpers = Front made by KMA and modified by me. Rear gate/bumper made by me.
Other stuff like Co2 PowerTank and Tuffy centerconsol...
Oh and I stuffed my factory guage cluster with AutoMeter guages.
FastTrack softtop too..
I think that about does it for ht emain items...
Burt
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 04-10-2007, 12:45 PM   #7
vtblazer
vtblazer's Avatar
Oops forgot about my CO2 Power Tank. (thanks Burt)
and the current photo.
Old 04-10-2007, 01:07 PM   #8
Burt4x4
Burt4x4's Avatar
Well now were even cuz your pic reminded me about my Warn 9500 winch I forgot to list
Old 04-10-2007, 04:11 PM   #9
Yukon Jack
Post Whore
Yukon Jack's Avatar
Here are the specs for my 1969 K20:
6" Tuff Country heavy duty front springs which really net about 7" of lift
ORD 4" shackle flip with some added leafs from another spring pack
3" body lift (going to be reduced before too long)
35x12.50x16 Super Swamper SSR's on 16 x 8" rims
1989 454 converted to carb, Crane Energizer 266 cam, Weiand Action Plus intake, Jet Stage II 800 cfm quadrajet, Dynomax Ceramacoated headers, dual exhaust with an x-pipe and Dynomax Ultraflo mufflers, MSD ignition
Hydroboost and hydraulic clutch from 1989 1 ton
3/4 ton Dana 44 closed knuckle front axle, Eaton HO52 rear axle with factory No Spin (Detroit Locker) both with 4.56 gears
SM465 with Rockwell T221 transfer case
Late model seats and some custom touches to the interior
AutoMeter Phantom gauges
Tilt van column modified for 4 speed manual
Custom gas tank on custom flatbed
And here are the specs for my 1970 K5:
1978 3/4 ton Dana 44 and 14 bolt FF with Detroit Locker, both with 4.11 gears
Rebuilt 400 sbc bored 20 over, RV cam, Eldebrock Performer intake, Jet Stage II 800 cfm quadrajet
SM465 and NP205 transfer case
4" front lift, 2" rear blocks with custom spring perches to level it out
1978 power brake master cylinder
Bikini top
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 04-20-2007, 10:09 PM   #10
Blue_71
Bloo
Blue_71's Avatar
well, its nothing fancy, but heres my '67-68-69-70-71-72 K20 (yes, thats only one truck ):
98 K3500HD 350, 1989 throttle body heads, ported and polished, stainless steel 1.94/1.5s. mid 90s LT1 hydro-roller cam, 89 K2500 throttle body, ramshorns, 2" pipe, thrush glasspack
SM465 with broken bellhousing ear
NP205 with stripped shifter bolt
eaton corp/dana 44, 4:10 gears
mud tires: 285/75/16 buckshot maxxis mudders on 16x7 whitespokes
going places tires: 285/75/16 goodyear wrangler at/s on 16x7 chrome modulars
and the 89 K2500LD:
89 350 with 246,000 miles
SM465/NP241
3.73 SF14 bolt, and whatever that excuss of a differential is in the front
cracked frame
265/75/16 Mud Kings on 16x8 Eagle 0589s
i do have a 1990 frame at a welding shop right now getting reinforced
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 04-20-2007, 10:19 PM   #11
1969k10stepside
The 71.........350 bored .06 over.RV cam,edelbrock intake/carb.Rebuilt TH350,NP205.Rebuilt front and rear axles.44 front,12 bolt rear.6" suspension lift (all spring lift).35" Pro Comp Mud Terrains Body,rusty now,will be solid and straight eventually.It has parts spanning across the 67-72 era.Atleast one part from every year.Also has some 72 K5 Blazer parts.
The 79......Worn 350,Rebuilt TH350,NP203.4" lift,33s.Just basically keep around to haul parts...
The 69 (not pictured) is pretty stock.Except the wheels,tires,and lift.It will be transforming to a K30 later this year.Nothing worth talking about on it at the moment
Top pics are of the 71(while motor is out being rebuilt.
Bottom is the ol 79 attempting with the 5 or 6 cylinder motor (worn out badly!) and 3:73 open axles to climb the rock pile
1969k10stepside is offline   Reply With Quote
Old 04-20-2007, 11:14 PM   #12
62 short step
62 short step's Avatar
Here is mine 61 4x4, 283 bored .060 edelbrock carb, cam & intake, sm420, rockwell t221 transfer case, dana 44 closed knuckle front soon to be changed to an open knuckle, gm 12 bolt rear. 3.08 gears and 265/75/16 inch tires. Basically stock. Soon to be painted, one day!
62 short step is offline   Reply With Quote
Old 04-20-2007, 11:44 PM   #13
customcamper72
72 K20, 350,sm465/205, dana 60 front w/ detroit truetrac, 14 bolt rear detroit locker, 4:10 gears, 6" tuff country spring lift, 38-13-16 superswamper tsl's, sorry no pics yet.
almost forgot, 4 wheel disc brakes.
customcamper72 is offline   Reply With Quote
Old 04-21-2007, 10:53 AM   #14
`72 K/20,350,SM465/205,Centerforce Dual Friction,HO52/Detroit Locker/4.10,6" TuffCountry,12.50/35x16 ProComp Xterrains.Dana60/TruTrac & 37" SuperSwamper SSRs on the sideline.Thinking on a LocRight,though.
Old 04-28-2007, 11:02 PM   #15
msgross
msgross's Avatar
pretty calm turck...
1968 K-10 SWB fleetside, 2nd owner,
Original: 327 cid, 4 bbl, 4 speed, tow hooks, HD cooling, bench, marker lights, tach, West Coast JR mirrors,
Added: front Corp10 discs, posi rear, rear add-a-leaf, 33x10.5 TA's, 15x8 MT's, SS brake lines, NOS wood floor, rear Reese hitch, power steering, 1 ton brake system, rear poly tank, poly bushings (everything), tilt wheel, urethane coated frame and suspension,
Possible upgrades:Rancho 9000 in cab system, Buddy Buckets, Halogen lighting upgrade, paintjob!
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 04-29-2007, 12:17 AM   #16
davidstadelman
i have a 1969 k-10 witha 350. what would have been the stock rearend and front end.
davidstadelman is offline   Reply With Quote
Old 04-29-2007, 01:48 AM   #17
ND_guy
Tool Addiction=Money Shortage
ND_guy's Avatar
My sig says it all, but it will soon have a shackle flip so I can get rid of the blocks.
1967 K20 400TBI SM465/NP205
posi front, Detroit locker 4.56 rear
ND_guy is offline   Reply With Quote
Old 04-29-2007, 08:45 AM   #18
msgross
msgross's Avatar
12 bolt in the rear and closed knuckle (w/drum brakes) dana44 in the front stock.
The Garage:
Old 04-30-2007, 03:13 AM   #19
bigtruck81
my 93 is currently under the knife...
out with the 14SF, IFS...
in with a HP60 and a 14FF. 5.13 gears in both, Detroit in the rear along with discs using Sky manufacturing brackets.
stock 4L60E is in the shop getting beefed up, should be done by Tuesday, and it will be backed by a NP241 outfitted with a JB conversions SYE, HAD flange. both shafts will be built by HAD.
springs are 4" TC EZ Rides in the front, 3" TC EZ Rides in the back.
ORU brackets in the front, ORD shackle flip in the back.
17" black DC1s, wrapped in 37 x 12.50 Goodyear MTRs (should be in VERY soon, were on national backorder)
bigtruck81 is offline   Reply With Quote
Old 04-30-2007, 05:07 AM   #20
vtblazer
vtblazer's Avatar
Nice.
We need pics of it for sure.
What's the intended "use"? Will it be a driver/weekend trial ride?
Old 04-30-2007, 07:00 AM   #21
I have a perfect truck to do all this to.A`92 K3500 5spd 6.5TD.And the 6.5 is a marine-duty 300hp!!If I can come up with another work truck w/o selling this,that`s my plan.It`s been the plan since I factory ordered this truck.I even have a RH-drop NP241 to "pop" in there so I can use one of my GM D60s.I`d like to keep it looking factory just to be subtle(and mess with a few minds.
Old 04-30-2007, 09:40 AM   #22
MJN
MJN's Avatar
1979 Chevy Suburban. 350(Weiand single plane aluminum intake, cam, flat top pistons), SM465/NP205, Dana 44 front/Eaton HO52 rear (welded), 4.10 gears. 6" suspension lift, 38.5x11x16 TSL Boggers. Warn front winch bumper, roof mounted spotlight, CB radio, 2 speed school bus fan (roof mounted inside). Has an '88 tub with Silverado trim. All gauges and vents still work.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 04-30-2007, 08:31 PM   #23
b454rat
Guess I'll post up too!!!
1989 K3500 reg cab long box
454TBI all stock, runs 100% perfect
TH400, 2wd from a short bus, 208/241 adaptor, 2" thick spacer machined to fit Ford t-case
Ford 205 case, twin sticked, just need to get some levers
HP60 from 78 F-250, Powrlok, 4.56s, GM outers from the knuckles out, calipers ground to run 15" rims
14ff from a 93 3/4 2wd, (pull off drums) 4.56s and a Detroit
Stock shafts front and rear for now, but hopefully can afford a HAD 1410 CV shaft up front, and will be getting a 1410 rear shaft
Currently has ORU SAS kit, but taking that out and gonna make my own, moving the axle foward an inch to clear fender/firewall
Homemade shackle flip, 6" Procomp springs, 2wd lowering shackles, 73-87 front hangers (about 2" lift)
Currently has 8" Superlifts, but have a set of BDS waiting to go in when I redo the front crossmember
40" boggers on 15x12 Bart wheels, 8 lug with 3.25" BS.
Cutout fender flairs
Not a straight panel on it.
If I can sell some stuff, a doubler is gonna go in, along with a rebuilt 400/203 that I picked up for $100. (Not rebuilt yet tho)
Only pics I have are in my sig, but I just took some more today, need to get them put on a disc. I put my stock 93 S-10 Blazer next to it, and the top of the Blazer is about the height of the bed.
Here is a pic, about 6" bigger now.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
