Old 04-09-2007, 10:07 PM   #1
stefan
New Member
torque specs for u bolts on lower control arms
what is the torque spec for the lower front u bolts for the shaft kits.
stefan is offline   Reply With Quote
Old 04-09-2007, 11:01 PM   #2
pissonNOS
senior member
pissonNOS's Avatar
Re: torque specs for u bolts on lower control arms
i believe but im not sure seeing as i threw my instructions out when i was done but ECE recomended 215 LBS? if this is wrong im sure someone will let you know but im pretty sure
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 04-10-2007, 02:49 AM   #3
royo
royo's Avatar
Hello be sure to use some sort of lock tite on the threads so that they dont come loose ive allready had a problem with them coming loose
nickle and dime
royo is offline   Reply With Quote
Old 02-13-2009, 01:52 PM   #4
short-t
short-t's Avatar
I know I am digging up an old thread but I just need to clarify that 215lb-ft is not the correct torque for these! If you don't know what it is why even post what you think it is???
For 9/16 lower control arm u bolt torque specs is 75lbs/ft, right from ECE!
short-t is offline   Reply With Quote
