Old 04-09-2007, 10:33 PM   #1
bagged69c10
soon to be bagged64sub
bagged69c10's Avatar
2 piece Drive Shaft????
As you can see in my other thread I just Zd my frame 3". My problem is that my driveshaft was about .25" from hitting my crossmember where my upper bars mount before I Zd it. SO now that it is Zd, the front of the driveshaft is moved up 3" therfore it is definately gonna hit now. Im thinking about running a 2 piece and putting the carrier bearing on that crossmember. Would this work? Any pros and cons would help. Thanks alot.
1969 c-10, bagged, Zd, 20" Boyds SOLD!
1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726
1965 c-10 long bed
1993 Sierra x-cab
1999 tahoe-4/5 on 22s
2005 Chevy work truck
bagged69c10 is offline   Reply With Quote
Old 04-09-2007, 11:59 PM   #2
jlaird
jlaird's Avatar
Re: 2 piece Drive Shaft????
Don't think it's gonna work man. I think you have to cut the cab. I have a two piece and no Z, and my drive shaft is almost hitting the cab, and I am an inch from laying out.
jlaird is offline   Reply With Quote
Old 04-10-2007, 10:38 AM   #3
bagged69c10
The cab is not the problem. I cut the cab before the Z. Its the crossmember that my upper bars go to that I dont wanna cut out. Ill post a pic of the crossmember Im talking about.
1965 c-10 long bed
1993 Sierra x-cab
Old 04-10-2007, 10:40 AM   #4
bagged69c10
This is what Im worried about. I guess Im just trying to find an easy way out.
1965 c-10 long bed
1993 Sierra x-cab
Old 04-10-2007, 02:07 PM   #5
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
with that setup, i would think a 2 piece driveshaft would work just fine. mount the carrier bracket to your x member that you made. Depending on where your x member is compared to factory, you'll probably have to get a drive shaft made for your truck.
IvelDesigns is offline   Reply With Quote
Old 04-10-2007, 02:57 PM   #6
jlaird
jlaird's Avatar
oh ok. I agree with Ivel. Fabricate a bracket for the carrier bearing on your crossmember and get the shaft as high as you can. This will minimize your working angles. You should be doing all this at ride height so you can make sure all your working angles at the u-joints are within limits.
Old 04-11-2007, 02:09 PM   #7
bagged69c10
Would anyone happen to know the working angles? My truck had a 1 piece so Im kinda clueless on the 2 piece.
1965 c-10 long bed
1993 Sierra x-cab
Old 04-11-2007, 09:23 PM   #8
IvelDesigns
at ride height, all angles should be 2-3 degrees. do a quick search in these forums and you'll see a few threads on this topic.
Old 04-11-2007, 10:48 PM   #9
jlaird
jlaird's Avatar
this is a must read so you know why your doing what your doing!!!
http://www.airridetalk.com/articles/...-joint-enigma/
Old 04-12-2007, 12:26 AM   #10
bagged69c10
Very helpful link. I forgot about that forum! There are way to many forums to keep track of.
1965 c-10 long bed
1993 Sierra x-cab
