Old 04-09-2007, 10:42 PM   #1
84_4x4
84_4x4's Avatar
headers?
i have a 307 sbc that i am going to rebuild due to no compression on one of my cylinders and when i put it back together i am installing an hei system and i am going to use the wire looms pictured below. i need to know what the best style header to use so i don't burn up my plug boots and will look neat and clean with this setup this is a non ac and no power steering truck so shouldn't be anything like that to worry about
1971 c10 350ci long bed fleet side
84_4x4 is offline   Reply With Quote
Old 04-09-2007, 11:04 PM   #2
brak
brak's Avatar
Re: headers?
if you go with a set from "made for you" you don't have to worry about it.
http://www.made4uproducts.com/wire_looms.htm
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 04-09-2007, 11:05 PM   #3
84_4x4
84_4x4's Avatar
Re: headers?
i need new headers anyways and wanna use the looms i have but thanks for the link i will have to book mark it for my other vehicles
Old 04-09-2007, 11:29 PM   #4
bad72c10
bad72c10's Avatar
Re: headers?
Okay, speaking from experience here, if you use those looms, get a st of do it yourself plug wires, or they won't look or work like you want them to, trust me. But if they do end up the right way, they look great. Justin
'72 C/10 SWB 355/ broken TH350 and 3.07s Soon to be 355/700r4 and 3.73s
bad72c10 is offline   Reply With Quote
Old 04-09-2007, 11:37 PM   #5
RACINJASON22
GEARHEAD
RACINJASON22's Avatar
Re: headers?
You said other vehicals so the extra exspence on a good set of plug wire pliers is well spent IMO. I like the way you can make them fit just like you want them to. I make up all of mine since I did my first set. The best part is you can put a different boot on each and every plug end to maximize header clearence issuses.
72 SWB 2WD MY PROJECT
72 LWB 4X4 FUTURE PROJECT
SUBSCRIBE HEREBOARD VENDORS HERE
NORWOOD MEET SURVIVOR!
RACINJASON22 is offline   Reply With Quote
Old 04-09-2007, 11:48 PM   #6
dan42
dan42's Avatar
Re: headers?
Thanks for the site, brak -
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 04-10-2007, 01:29 AM   #7
84_4x4
84_4x4's Avatar
Re: headers?
i do have a set of do it yourself wires so thats not gonna be a problem now all i need is to figure out which headers i should run to make those wires look the best and not get burned up
Old 04-10-2007, 09:10 PM   #8
84_4x4
84_4x4's Avatar
Re: headers?
ttt
Old 04-11-2007, 07:20 PM   #9
Psycho71
Psycho71's Avatar
Re: headers?
Asking what kind of headers to run is like asking which kind of carb to buy. There's just too many opinions out there. But here's mine. If you want to spend the money, get a set of Thorley's. If your on a budget, Hookers are great (they're what I have). If your on a tighter budget, get Flowtechs (and buy a few sets of extra gaskets). Ceramic coated is always a plus too, but costs more $. . A lot of guys here like Headman so that's another option.
The possibilities are endless. I like hookers due to the collector flange. A lot of the cheapies have a ring flange and a flare on the end of the pipe. And they tend to have thinner flanges at the primary tubes.
I like them to have a welded flange at the collector, and a thick flange on the primary tubes. Mine's not a "looker" so I opted to not get ceramic coated, may regret it later, but I'll worry about that then.
Jay
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
If a hammer doesn't fix it, you have an electrical problem!
Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels!
Psycho71 is offline   Reply With Quote
Old 04-12-2007, 08:30 AM   #10
Re: headers?
I would have bought headers,then found wires and looms to work with the headers,personally.
