Old 04-09-2007, 11:45 PM   #1
Jondotcom
noob.. basic difference between c10 and c20?
I have a crush on the 67-72 C10/C20 line of trucks and I'm getting close to closing a deal on my 1st one. It looks like I'm settling on a particular local truck (72 GMC 3/4 ton long bed) due to the price and overall condition of the truck, but I'm ignorant of what the real difference is between the 1/2 ton and 3/4 ton besides rear springs, 8 lug spindles, and rear axle.
My general plan is to mosltly keep that original classic feel of the truck by restoring most of the original truck, but I'll probably do some subtle modern tweaks like change the color slightly, new interior, spray in bedliner, new wheels, and lower the ride height very slightly (1.5 inches or so).
I've noticed that the c10 is more popular/expensive in my area and honestly I haven't noticed even one c20 that was hot-rodded...why is that? Is there some fundamental reason the c10 is thought to be better by some?
I'd have thought the c20 would be a bit heavier duty including the posi and beefy rear end, but ????
Appreciate your input.
Thanks,
Jon
Jondotcom is offline   Reply With Quote
Old 04-09-2007, 11:48 PM   #2
corn
Re: noob.. basic difference between c10 and c20?
c-10 is 1/2 ton
c-20 is 3/4 ton
corn is offline   Reply With Quote
Old 04-09-2007, 11:55 PM   #3
dan42
dan42's Avatar
3/4 tons rock - there's lots of 'em around but they're hard to find in good shape because they were used more for actual "working" trucks. I love mine and am not sure I would want a 1/2 ton. It's got a real truck feel to it and it actually corners a little better. I don't know if there's a whole lot of difference other than what you just mentioned, though.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 04-10-2007, 12:02 AM   #4
sighlurr
______________
sighlurr's Avatar
I've had a handful of 1/2 tons and one 3/4 ton. The 3/4 ton had a much stiffer ride. I think that's because they were built to carry a load or be under pressure from towing. When the truck was empty, it had a very pogo-like ride which wasn't comfortable for longer trips. The 3/4 is heavier and could hurt you at the pump a little more. My .02.
sighlurr is offline   Reply With Quote
Old 04-10-2007, 01:02 AM   #5
short69
short69's Avatar
somtimes it feels like the rear shocks on my c-20 are locked up or somthing. I think the brakes are a little more heavy duty on the 20 series. another good thing about the 3/4 tons is that they usually have lower gears in the back which makes for nice burnouts!!!!
69 shorty w/ 67 front clip
short69 is offline   Reply With Quote
Old 04-10-2007, 01:05 AM   #6
WorkinLonghorn
WorkinLonghorn's Avatar
The C20 (or 2500 in GMC terms) also has beefier brakes,frame and suspension.They came with full floating rear axles (if one breaks,the wheel stays attached) and often heavier duty rear diff. I guess the 1/2 tons are valuable for their lighter weight (= quicker ride).But for work or towing it's 3/4 or 1 ton for sure.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 04-10-2007, 12:12 PM   #7
Jondotcom
Thanks for all the replies. I will try to get the local c20 if it isn't sold.
I'll post pics if/when it's mine Before shots that is
