Old 04-09-2007, 11:56 PM   #1
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Painting Door Panels w/Marhyde or Duplicolor
Anyone ever done this? It has been years since I have but since I can't get any stock white '68 panels I am thinking about painting some tan ones white with Marhyde or Duplicolor vinyl paint. Anyone have better luck with another product?
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 04-10-2007, 12:41 AM   #2
Livrat
Member #1049
Livrat's Avatar
Re: Painting Door Panels w/Marhyde or Duplicolor
Mike.. I have used various different ones over the years. and have found that the "SEM" brand vinyl spray seems to hold up the best and last the longest
Livrat is offline   Reply With Quote
Old 04-10-2007, 01:00 AM   #3
Big D
Big D's Avatar
I've used marhyde quite a few times. I think the prep work determines how it will look as a finished product. I usuallly clean the panel with TSP and a brush, then use dupont wax & grease remover before spraying.
Of course being a door panel it may have to be touched up once in a while from your arm rubbing up against it.
68 GMC
64 1/2 Mustang convert
A bachelor's life is no life for a single man."
- Samuel Goldwyn
Big D is offline   Reply With Quote
Old 04-10-2007, 01:31 AM   #4
Americanrider
This what your stllookn for? I had to do that... PM sent
Americanrider is offline   Reply With Quote
Old 04-10-2007, 01:34 AM   #5
stllookn
stllookn's Avatar
Thanks guys...Ill try it. I did some seats on a hot rod years ago and they lasted a year on the seats with lots of use so door panels should last alot longer. The new "PERFECTLY EXACT" restorations cost more than the truck...but that is not saying much...LOL! I'll look for some SEM and Big D thanks for the reminer on the Prep-Sol or wax and grease remover. I will buy new skins ($74/set) so they should not have any Armorall on them!
Old 04-10-2007, 01:59 AM   #6
sameyrasmea72
sameyrasmea72's Avatar
I have had good luck with the duplicolor too. Like the others said, being clean is the secret. Also do several lite coats with the first 2 or 3 coats being more or a dusting.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 04-10-2007, 07:24 AM   #7
70GMCer
70GMCer's Avatar
I've always used Krylon or Dupli-color "Satin" paints on "Plastic" door panels, which these are. Use 2 or 3 light coats. Again, clean well before using. I wipe them down with either alcohol, or thinner. I think that the vinyl paints do not work as well on plastic and do not hold up. IMO, they are meant for vinyl and upholstery.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 04-10-2007, 08:51 AM   #8
OLDIRON69
I have "dyed" alot of vinyl and plastic interior parts, always you an adhesion promotor and clean the hell out of it, acetone works as good as any, just check the material in a small area with what you are cleaning it with just to make sure it dosen't "gum" the material. On some items I have used regular old krylon brand paint (don't forget the adhesion promotor) Wal-Mart has it in the auto paint/body section. It is worth it to spend a few extra bucks here.. I have used the duplicolor on exterior plastic pieces like the grille teeth and held up fine. I have a couple Mopars and they all have been duplicolored and dyed on panels,pieces you can't buy new.
05 2500HD 6.0 excab
69 LWB-Gone but not forgotten!
68 Dodge Charger 383/727
69 Dodge Charger-440/4spd
OLDIRON69 is offline   Reply With Quote
Old 04-10-2007, 02:09 PM   #9
BigSky71
LAIDOUT
BigSky71's Avatar
I just painted my door panels and visors with PlasticKote brand vinyl paint. I was real pleased with the results. Haven't put them to the test though as far as durability.
67 2wd Shorty
Build Pictures
BigSky71 is offline   Reply With Quote
