Old 04-10-2007, 01:05 AM   #1
SCOTI
SCOTI's Avatar
Blazer Tank Swap Question/Issue
I picked up a blazer tank swap kit for my Beater & tonight I was doing some test fitting of the tank.
I had to remove the spare tire cross-member as expected & the factory punched holes in the frame line up like they should vs. the holes on the reinforced tank flange.
The issue I'm noticing is the front of the tank on the drivers side does not clear the pan-hard bar mount. Either the tank flange or the pan-hard bar mount will need to be trimmed...... or possibly both.
Has anyone else that's done this conversion had a similar problem? What was your solution?
Just asking questions to make better decisions. . .....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-10-2007, 01:11 AM   #2
gringoloco
A guy with a truck
gringoloco's Avatar
Re: Blazer Tank Swap Question/Issue
I moved my tank back as far as possible and drilled new holes for the straps. I used a poly tank though, so no flange...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 04-10-2007, 08:35 AM   #3
SCOTI
SCOTI's Avatar
Thanks Gringo.
Anyone else w/a steel tank?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-10-2007, 09:00 AM   #4
I didn't notice any problems on mine, but mine is an original blazer tank. Its not super roomy back there but it clears fine.
This is the only side shot I have of mine.
Palf70Step is online now   Reply With Quote
Old 04-10-2007, 11:29 AM   #5
SprayPaint
Hey Scoti,
Let me know how your conversion goes. I live next to LMC Truck and was just about to buy their Blazer Tank Conversion kit for my '67 for $199 w/sender. My initial measurements show it hanging a little lower than I care for but might still be ok.
SprayPaint is offline   Reply With Quote
Old 04-10-2007, 03:02 PM   #6
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Here is an old post w/pics that might be of help.
http://67-72chevytrucks.com/vboard/s...ad.php?t=74876
sneakysnake is offline   Reply With Quote
Old 04-10-2007, 03:05 PM   #7
SCOTI
SCOTI's Avatar
Thanks. I've already read that thread & he didn't seem to mention the issue.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
