Old 09-06-2002, 01:24 PM   #1
sam's 72
Trying to find a fitting to check fuel pressure! HELP!!!!!!!!
I am working on diesel engine. I want to check the fuel pressure at the fuel rail, I have a liquid filled pressure gauge, and a hose hooked to it, what I need is a fitting that will screw on to a shrader vavle. The same size shrader valve that a valve stem on a tire is. Does any body know where I can get this? I have checked about 4 parts houses here, and no one carries it. I looked through all of my parts catalogs, and still no fitting. It there a internet site that I can order one from, any suggestion?
Sam
72 LWB chevy truck.
Pasadena, Texas
sam's 72 is offline   Reply With Quote
Old 09-06-2002, 01:37 PM   #2
Michael A. K. G
Just about any fuel pressure tester for EFI should have what you are looking for. You do not want to use a carburated gasoline engine pressure tester. You will blow it out. They aren't meant for high pressure.
I think I bought mine from Sears for $30.
Michael A. K. G is offline   Reply With Quote
Old 09-06-2002, 03:22 PM   #3
sam's 72
The one I got is for high pressure, all I need is the fitting that screws on to the shrader valve, and I will be ready to go. Any ideal where I can get one
sam
72 LWB chevy truck.
Pasadena, Texas
Old 09-06-2002, 09:31 PM   #4
Mike C
Mike C's Avatar
Some diesels have around 1600 psi of pressure in the rail... not sure about the one you are working on. Northern Tools automotive catalog has a diesel psi tester, but they aren't cheap. Comes with adapters, hoses and gauges for just about any combo.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
