Old 04-10-2007, 06:18 AM   #1
69rut
Id I-6
I have a I-6 in the truck I am restoring. 1969. How can I find out what the displacement is? Are there numbers/codes stamped into the block? I want to sell this engine and it would be nice to tell interested parties what they are looking at.
trailers are for boats
69rut is offline   Reply With Quote
Old 04-10-2007, 06:32 AM   #2
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: Id I-6
A dress number will be stamped into a pad on the passenger side just behind the distributor position. That's usually the date the engine was assembled on plus a 2 or 3 letter code... [My L6 292 is stamped, F0626UH] There's a casting number cast in raised digits that give the date the block was cast on the drivers side of the lower block near the rear.
The way to tell a 292 from the smaller L6s is to measure the height of the lifter cover panels on the passenger side. A 292 is about 6" high, a 230 or 250 would have 4" high covers. 292s have asymmetrical motor mounts, the passenger side mount is forward of the fuel pump. On a 250 the fuel pump is in front of the motor mount, opposite the one on the drivers side. 292s are 1 3/4" taller than the smaller L6s.
Old 04-10-2007, 10:29 AM   #3
shifty
Questionable
shifty's Avatar
Re: Id I-6
Post a picture of the passenger's side of the engine, most guys here can tell you the difference. Meanwhile, I found this using the forum's search feature:
http://67-72chevytrucks.com/vboard/s...line+fuel+pump
It's an old post I made explaining the differences.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
