Old 04-10-2007, 07:20 AM   #1
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Cleaning & painting engine bay.
I’m trying to get my truck ready for the new engine.
I made a wooden support for the transmission that spans across each side of the frame and is bolted with 2 bolts. As soon as the weather gets better I plan on rolling it out of the garage.
Does anyone have some good advice on cleaning this? Would TSP work? I don’t want to mess up the paint on the out side. I’m considering painting the fire wall to correct some unsightly areas- mainly around the brake res. which has leaked at some point and messed up the paint.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 04-10-2007, 08:32 AM   #2
superman3405
Junior Member
superman3405's Avatar
Re: Cleaning & painting engine bay.
I ended up cleaning with a brush and some soap while my engine was out, then took a can of gloss black spray paint and went over the firewall and fenders, taping a small tarp to the outer paint so I did not get any on it. It is not show quality by any means but certinaly cleaned up all the scratches and discolorations. Once I put the new motor in I thought to my self that looks pretty good. Good luck
1972 Chevy C-10 Short Bed (Ol'Blue)
350/350TH
2003 Chevy Silverado Z71
2007 Honda MiniVan...yup we should all be so lucky
superman3405 is offline   Reply With Quote
Old 04-10-2007, 09:55 AM   #3
I`ve cleaned them up with laquer thinner,then washed with soap.
Old 04-10-2007, 10:13 AM   #4
shifty
Questionable
shifty's Avatar
Pressure washer. Be sure to scrape any lumps of grease off with a putty knife before going over anything.
If it's just simple grime, Simple Green removes things very well, is environmentally safe (will make your grass nice and green ), and safe for paint. I use it to clean my wheels.
A lot of the guys here use oven cleaner to get off serious grime, and I'll tell you what, it does work for caked on grease. Nothing shy of sandblasting beats a pressure washer though.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 04-10-2007, 10:25 PM   #5
Sport/Truck
Sierra Grande Club
Thanks for all the great suggestions. I’ll get the power washier out and some simple green (I didn’t know it was environmentally friendly). I’ll connect it to the hot water from my boiler to help cut the grime.
I think I’ll look for some factory paint in an aerosol can, perhaps from my local paint shop.
s/t
Old 04-10-2007, 11:10 PM   #6
ChevyDude
Oven cleaner works wonders...let it soak...blast, scrape , re apply and soak and re soak, repeat, repeat....that's how I did mine
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
Old 04-11-2007, 11:32 AM   #7
wibilly
wibilly's Avatar
be carful running hot water though your power washer. only the best quality pumps seals will hold up to hot water. check with manufacture to avoid damage to your pump
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 04-11-2007, 11:51 AM   #8
shifty
Questionable
shifty's Avatar
I just used regular water from the hose, and used the 15º nozzle (tight angle). I used this setup to completely blast the grease and oil off my inline 6 when i pulled it out, and used it to clean out the entire bay when the drivetrain was out.
Old 04-11-2007, 04:42 PM   #9
EAST SIDE LOW LIFE
EAST SIDE LOW LIFE's Avatar
Superman has the right answer on this one! Do what he suggests, do a gental scrub, take your time rinse with clear water and sponge. Let dry and take the time as he say's to protect your paint. Pick your paint semi flat or gloss and ..... whow does that look good.
esll.
(Post a pic of the fresh engine bay ..... )
Tomorrow is for doing today's stuff.
This truck has just the right amount of energy for me!
Author: Warren Lake .... (member)
EAST SIDE LOW LIFE is offline   Reply With Quote
Old 04-11-2007, 05:48 PM   #10
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
wibilly is right about the hot water.I use steel wool to do the final cleaning and give the old paint some "tooth" to adhere to.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 04-12-2007, 10:01 PM   #11
Sport/Truck
Sierra Grande Club
esll.
I’m glad I didn’t use the hot water before reading this!
Any specific oven cleaner I should use?
Steel wool, what grit? After reading about oven cleaner I automatically thought of the brass steel wool things for cleaning dishes lol.
Thanks,
s/t
Old 04-13-2007, 09:40 PM   #12
WinDancer
The Original HotRod KnifeMaker
WinDancer's Avatar
You might want to consider semi-gloss. The full gloss is a ***** to keep clean. The semi doesn't show fingerprints so bad and still wipes clean.
Post some pics when you finish?
Good luck
Dave
69 GMC SWB 2WD 454 Turbo 400
WinDancer is offline   Reply With Quote
Old 04-14-2007, 12:59 AM   #13
RetroSBK
Second the oven cleaner! It works awesome! understand that oven cleaner, or a pressure washer will quickly take it down to bare metal, which if you even TOUCH it, will leave a rusty fingerprint, even under the paint...
My process is pretty simple, but works great...
Bag the entire truck body thats still on the frame with visquen, using duct tape to seal the seams closed.
Spray the entire area down with a serious foamy coat of EZoff oven cleaner, aloowing it to sit for 20-30 min (best to do on a nice warm day) scrape the heaviest areas with a putty knife and a wire brush (be SURE to wear eye protection, breathing protection, and big ole kitchen dishwashing gloves, along with clother you wont ever wear again)
Then, get out the pressure washer and blast the hell out of it! remember that every part has at least 4 sides to it, so be sure to get under and around all the nooks and crannies.
When you are done there..... break out your leaf blower, and blow the area dry, without touching it with your hands or clothes
Using some lint free towels, wipe the entire area you just cleaned with PrepSol, and mix some etching primer, then spray it onto every surface you just cleaned, blasted, and treated. You can get this in spray cans too.
Once that has had flashed, spray with some semi gloss paint, in small light coats, and finish with a urethane clear. Be sure to use the clear, as it makes it a lot more durable!
Hope this helps! Good luck!
Will
1970 C10, shortened long bed, Alum Headed full roller 383 (with Victor, 750DP, stainless rockers, behive springs, CNC ported heads) TCI SSF 700R4, 4.10 Posi, Bagged on C-Notch and 2.5 spindles. Air Cond, black out tint, satin black paint, custom interior, rolling low and not so slow...
RetroSBK is offline   Reply With Quote
Old 04-14-2007, 01:08 AM   #14
cstm68
cstm68's Avatar
thats what i did
check out my build thread for the after pics
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308
2014 Chevy 2500hd duramax CCLB
cstm68 is offline   Reply With Quote
