Old 04-10-2007, 03:11 PM   #1
oldschooler
oldschooler's Avatar
distributer hold down not holding(HELP)
Hi Everyone, I am having trouble with my dist. drifting around. I bought a new chrome hold down and still having same problem. I took stock hold down and bent it a little at the ends and still no luck. Could it be that my dist. is worn out? It is a small block built in 1995, not by me. I just bought the truck a couple of months ago. This problem came with the truck
oldschooler is offline   Reply With Quote
Old 04-10-2007, 03:16 PM   #2
Tman
Tman's Avatar
Re: distributer hold down not holding(HELP)
Could the hold down bolt be to long and be bottoming in the threads b4 clamping the dist. down? Can you move the dist. by hand after tightening the hold down?
Tman is offline   Reply With Quote
Old 04-10-2007, 03:16 PM   #3
RACINJASON22
GEARHEAD
RACINJASON22's Avatar
I was gonna say bend it a little till I read that part.....hmmmm. You said you bent the old one at the ends so I might suggest that it really needs to have a kind of arch to it say like a leaf spring so to speak. If this is what you did then you got me stumped. I can't see a dizzy itself wearing out at this area IMO.
Tman has a very good point also.
72 SWB 2WD MY PROJECT
72 LWB 4X4 FUTURE PROJECT
SUBSCRIBE HEREBOARD VENDORS HERE
NORWOOD MEET SURVIVOR!
RACINJASON22 is offline   Reply With Quote
Old 04-10-2007, 03:31 PM   #4
BUDDY
Global warming is a myth
BUDDY's Avatar
Thumbs up Re: distributer hold down not holding(HELP)
If this is the problem it's easily fixed. Just slam a washer or two under there until it gets tight & stays tight.
Later,
Buddy
Henderson, NV
1972 K5 - Lifelong project - Needs Time, Place, Help & Parts!!
1990 K5 with 37's
2003 Discovery SE7 - Wife's
BUDDY is offline   Reply With Quote
Old 04-10-2007, 03:31 PM   #5
70-Chevy
-Chris
70-Chevy's Avatar
Do you have the little o-ring distributor gasket in? I thought of this since I just put a distributor in for my dad this past weekend and had the same problem. Good luck
Chris
1970 Chevy C-10 P/U, Shortbed, Fleetside - 5/7 drop, 496, TH400, 12 bolt.
BUILD THREAD - http://67-72chevytrucks.com/vboard/s...d.php?t=404481
2012 F250 Super Duty P/U - intake, exhaust, tuner, 4" lift with 35's
2017 Chevy Suburban (Wifes Car)
- Fully Loaded & Stock
"Some people spend an entire lifetime wondering if they made a difference in the world. But, the Marines don't have that problem."
Ronald Reagan, President of the United States; 1985
70-Chevy is offline   Reply With Quote
Old 04-10-2007, 03:38 PM   #6
oldschooler
Thanks for the info, I dont know about the rubber gasket, i'll have to check. I thought about the bolt being too long and put a stud in the intake w/a nut. I also thought about the washers under the hold down but afraid of it vibrating out, I guess I could weld the washers to the hold down. Thanks again for the info. Later, oldschooler
Old 04-10-2007, 03:41 PM   #7
oldschooler
I did forget to mention. Yes it will turn by hand, pretty freely.
Old 04-10-2007, 03:57 PM   #8
Bryan68custom
I had a problem with an edelbrock intake once and the only fix that I found that worked was a short stud that I put locktite on and used a nut with the washer made to it on top of the hold down
2004 Extended cab LS silverado
2001 Buick Lesabre
1968 Chevy Custom 10 LWB Anniversery model
2008 crew cab lt (rolling on dubs)
"The nice part about living in a small town is when you don't know what you're doing, someone else always does"
Bryan68custom is offline   Reply With Quote
Old 04-10-2007, 04:29 PM   #9
BUDDY
BUDDY's Avatar
Talking Re: distributer hold down not holding(HELP)
If you have a stud, the just put a jam nut on top. Once you figure out what the problem is, of course.
Later,
Buddy
Henderson, NV
1990 K5 with 37's
Old 04-10-2007, 04:34 PM   #10
jhow66
jhow66's Avatar
Throw the chrome one away (pop metal) and get a cast iron one (stock type). Problem solved. The chrome ones just bend flat when you tighten them. If that does not work your manifold may be thin at the dist. hole. Add another gasket or two under dist.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 04-10-2007, 08:14 PM   #11
corn
I bet if you pull the clamp you will notice the distributor base sits up just a bit too high. Just double the gasket, & problem solved...
corn is offline   Reply With Quote
Old 04-14-2007, 06:39 AM   #12
oldschooler
Thanks for all the info guys. Two problems fixed with one solution. I pulled dizzy and found the gasket was saturated with oil and very compressed. I replaced gasket and stock hold down works fine now. Also I figured out a puddle of oil, which I thought was from previous owner sloppily adding oil, was actually oil leaking out from under dizzy. Thanks again
Old 04-14-2007, 11:59 AM   #13
corn
Glad to see you got it fixed. Good job...
Old 04-27-2007, 06:04 PM   #14
rage'nrat638
rage'nrat638's Avatar
WAY TO GO BROTHER..
i love it when a plan come's together
rage'nrat638 is offline   Reply With Quote
Old 04-27-2007, 08:38 PM   #15
JAKES 68GMC
Aluminum slot wheels rule...
Like on the A-Team, its just great when the plan comes together in the end.
JAKES 68GMC is offline   Reply With Quote
Old 04-27-2007, 08:49 PM   #16
piecesparts
Parts and more parts
piecesparts's Avatar
Replace the bolt with a stud and then once the bolt is set in firm (using LOCKTITE), use a good nut to hold the dizzy clamp. The aluminum intakes can get the threads slightly worn and bolts do not hold.
piecesparts is offline   Reply With Quote
Old 04-28-2007, 02:54 AM   #17
mexgrhd68
mexgrhd68's Avatar
I agree, those chrome hold downs are worth a @!#$##@!! Chrome hold downs, they suck!!
mexgrhd68 is offline   Reply With Quote
